can you test dizzy's?
Hey so the other day i was driving my Crx si with an obd0 dohc zc when it started to shudder a little bit and the tach dropped to zero i figured it might have been the battery so i said screw it the alternator will charge it ( haven't driven the car in about 2 weeks) but it only got worse and eventually i came to a stop light and the car just shut off and wouldn't restart so i called my friend up to bring me some cables. But as i was waiting i tried to restart my car and didn't hear any clicking when id turn the ignition so i figured its my dizzy and just called a tow truck. I pulled my dizzy off and the pin in the cap is a little burnt and the rotor is a little hard to turn is there anyway to check if a dizzy is good i would hate to go out and blow $ if its not my dizzy that's the problem. I'm also using the same dizzy that came with my engine when i bought it thanks for you're time, any suggestions would help.
HatchGirl89
Nov 15, 2012 10:00 AM
em2ssm02
Jul 23, 2007 06:27 PM
JOGADOGGZ
12
Sep 10, 2005 08:21 PM
