Drum to Disc Swap
Old Jun 22, 2008 | 08:57 PM
puertoricanboy90's Avatar
Default Drum to Disc Swap
I have an 89 CRX Si and i absolutley love it! but unfortunately i want to autocross with it and i know that the drum brakes would not be able to sustain the extreme heats of racing. So i have a friend who is willing to let me remove his rear axles, bearing, brakes lines, discs, calipers, etc, from his 91 CRX. I'm pretty sure that this swap is possible. But would i also need the 91 master cylinder/ would i need to modify it to fit as well. I need more braking power seeing as i already have enough power with my D16Z6. Help?! thanks.
Old Jun 22, 2008 | 09:13 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Drum to Disc Swap (puertoricanboy90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by puertoricanboy90 &raquo;</TD></TR><TR><TD CLASS="quote">I have an 89 CRX Si and i absolutley love it! but unfortunately i want to autocross with it and i know that the drum brakes would not be able to sustain the extreme heats of racing. So i have a friend who is willing to let me remove his rear axles, bearing, brakes lines, discs, calipers, etc, from his 91 CRX. I'm pretty sure that this swap is possible. But would i also need the 91 master cylinder/ would i need to modify it to fit as well. I need more braking power seeing as i already have enough power with my D16Z6. Help?! thanks.</TD></TR></TABLE> You can't race with rear drums?
I've been really lucky for the past 4 years then!
There are many FAQs if you want to go to disks, but first of all understand it's not needed, and it'll possibly alter your class in autoX.
Old Jun 22, 2008 | 09:34 PM
blkef4dr's Avatar
the only thing youll need to replace the brake fluid perportioner valve
you can get at the junk yard off of any integra 90-00or civic 92-00 as long as it has
disc brakes on the back.you dont need to replace the master cylinder...
Old Jun 23, 2008 | 09:45 AM
CRX Toad's Avatar
Actually the drum brakes with stand a ton of heat and to change them for that reason is absurd. In actuality the drums brakes are lighter than the disc setup.
There are a ton of people that I race with that auto-x that run drum setups and have no issues. I think you need to read more info on it and not take one single persons advice.
Old Jun 23, 2008 | 09:49 AM
JustAnotherRex's Avatar
The main reason I would go with discs is the simple ease of servicing them.
Old Jun 23, 2008 | 02:53 PM
nathanaelsmalley's Avatar
Drum brake setup is far better than the discs. I have drums on my jap import they are considerably better than the rear discs on my friends crx sir, so much so that he has aquired a rear drum setup to swop over from discs.
Old Jun 23, 2008 | 02:59 PM
Ass$nyper's Avatar
Default Re: (JustAnotherRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustAnotherRex &raquo;</TD></TR><TR><TD CLASS="quote">The main reason I would go with discs is the simple ease of servicing them. </TD></TR></TABLE> Drum puller bro, best 29 bucks i've ever spent.
Old Jun 23, 2008 | 04:15 PM
Default Re: (***$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ***$nyper &raquo;</TD></TR><TR><TD CLASS="quote"> Drum puller bro, best 29 bucks i've ever spent. </TD></TR></TABLE>
That would have been good news prior to me deciding that some rear DA discs would look phat on my ride. Now I just have to source a proportioning valve and some lines (they'll go in after the engine)
Old Jun 23, 2008 | 11:58 PM
blkef4dr's Avatar
your stock line will mount right up
unless your getting steel braded
jacksonww
Feb 7, 2011 11:09 AM
littlebluecrx
Feb 13, 2010 04:54 PM
iheartmyh0nda
18
Jun 18, 2007 08:16 AM
enthusiast128
18
Nov 16, 2001 12:37 AM
allmotorEG-SI
Oct 24, 2001 05:06 PM
