B16A CRX with Y1 Transmission - Axle Issues
Old Jun 22, 2008 | 06:25 PM
c.dub's Avatar
Default B16A CRX with Y1 Transmission - Axle Issues
I have an '89 CRX Si with a B16A and Y1 transmission (it has LSD, I think that's the right model...). I have it swapped in with HASport mounts and linkage, and I am using Integra axles. AFAIK I have done everything right, however I am having axle binding issues, so maybe I didn't lol...
When I am driving it is fine, but when I turn a corner, it is grinding my axles and making a clunking noise that gets faster if I corner faster. If I corner aggressively, it doesn't seem to do it. Also, if I corner with the clutch pressed in, no grinding.
The motor came out of my friend's EF8, has 111,000kms, and the motor runs great. I drove his car and none of these issues were present while the motor was still in it.
I don't know what to do about this, so I need some help. Anyone have any ideas why this is happening?
Old Jun 22, 2008 | 07:13 PM
richmond's Avatar
Default Re: B16A CRX with Y1 Transmission - Axle Issues (c.dub)
what axles are you using? also how is your alignment, i remember one time my front toe was so off i had bad axle bind and it would clunk during turns.
Old Jun 22, 2008 | 07:21 PM
vtecb18c's Avatar
Default Re: B16A CRX with Y1 Transmission - Axle Issues (richmond)
how low is your car? it sounds like your axle pitch is off from being to low
Old Jun 22, 2008 | 11:26 PM
c.dub's Avatar
Default Re: B16A CRX with Y1 Transmission - Axle Issues (vtecb18c)
Tried DA and DC axles, also the car is at stock height. I adjusted my coilovers back up to stock.
The car drove straight but I haven't had it in for an alignment since the swap.
Old Jun 23, 2008 | 05:26 AM
gibsanez's Avatar
Did you remember to remove the dust rings?
Old Jun 23, 2008 | 07:15 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
Call Raxles and ask for Marty. I tried a gabillion different OTS axles and didn't get rid of my problem till i got my Raxles.
Old Jun 23, 2008 | 09:51 AM
vtecb18c's Avatar
Default Re: (ComeOnKip)
yea i think its time for new axles...who knows maybe you put a pin hole in the axle boot and it leaked all the grease out....but imo raxles or gators if you want to spend the money...and about the alignment, it would have to be way way way off for it to mess with the axles and you didnt say you were having steering issues or anything like that...which to me sounds like a bad crappy re man axle
Old Jun 23, 2008 | 12:51 PM
richmond's Avatar
Default Re: (vtecb18c)
also highly recommend an alignment heh
Old Jun 23, 2008 | 01:24 PM
revikan's Avatar
Default Re: (richmond)
make sure ur axles are for non abs
Old Jun 23, 2008 | 02:03 PM
red civic standard's Avatar
Default Re: (revikan)
I believe that the problem you are having is with the limited slip differential and not with axle bind.
The JDM EF Y1 gearbox has a clutch type limited slip differential. It requires special fluid because it is a clutch type differential. If you do not use the special fluid, then the differential will hop when you are turning.
I used GM LSD additive with GM syncromesh back in the day and it worked great.
Modified by red civic standard at 2:14 PM 6/25/2008
Old Jun 23, 2008 | 03:34 PM
c.dub's Avatar
Default Re: (red civic standard)
I have used a Honda trans. fluid made for LSD. Dust rings I am not sure of. ABS or Non-ABS axles I am not sure of either, I would assume Non-ABS, but I will find out. I will get an alignment once this is sorted out for sure.
I got help from friends who have done B16 swaps before to do this swap for me. I just don't have enough tools to do it on my own. However, none of them have done a B16 EF swap with this transmission before AFAIK.
The car is with a local Honda pro right now who has been in the game for like 20 years so hopefully he can figure something out. Anything I find here I will relay back to him as well. I don't know if he is on here.
Thanks for all the help so far guys.
Modified by c.dub at 1:44 AM 6/24/2008
Modified by c.dub at 1:45 AM 6/24/2008
Modified by c.dub at 1:46 AM 6/24/2008
Old Jun 23, 2008 | 05:33 PM
Kool_Aid's Avatar
Im pretty sure its a combination of civic and integra drive shafts.
Old Jun 23, 2008 | 06:08 PM
Runnerdown's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote">
The JDM EF Y1 gearbox has a clutch type limited slip differential. It requires special fluid because it is a clutch type fluid. If you do not use the special fluid, then the differential will hop when you are turning.
Just wanted to note that LSD was an option and not installed on all the Y1's
Old Jun 23, 2008 | 06:58 PM
downest's Avatar
Default Re: (Runnerdown)
If you took it out of a real EF8 it's because the intermediate shaft is the wrong size. You need either the EF8 driver side axle or a DA midshaft.
Old Jun 24, 2008 | 10:06 AM
c.dub's Avatar
downest, can you explain that again in a bit more detail?
Thanks for the input everyone I really appreciate it.
Old Jun 24, 2008 | 03:12 PM
crxsiturbo's Avatar
are you saling your b16 lsd tranny? is it a civic si? if it is a civic si how much you want for it?
Old Jun 24, 2008 | 03:24 PM
c.dub's Avatar
Default Re: B16A CRX with Y1 Transmission - Axle Issues (crxsiturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsiturbo &raquo;</TD></TR><TR><TD CLASS="quote">are you saling your b16 lsd tranny? is it a civic si? if it is a civic si how much you want for it?</TD></TR></TABLE>
Old Jun 24, 2008 | 03:28 PM
c.dub's Avatar
Also, for further clarification, the motor came out of my friends real CR-X siR (EF8). It was brought in directly from Japan, and is (was) all original.
Old Jun 24, 2008 | 06:38 PM
Default Re: (c.dub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c.dub &raquo;</TD></TR><TR><TD CLASS="quote">I have used a Honda trans. fluid made for LSD. Dust rings I am not sure of. </TD></TR></TABLE>
I didn't think honda made fluid specifically for clutch type LSDs?
Are you just using honda mtf?
Old Jun 25, 2008 | 06:59 AM
c.dub's Avatar
I believe that is the one. I was informed that is the correct fluid? What should I be using??
Old Jun 25, 2008 | 10:24 AM
c.dub's Avatar
Default Re: (c.dub)
Took the car for a drive.
When you corner aggressively, it does not bind. If the clutch is pressed in while cornering, no bind either. Only on slower corners does it happen. Drives straight.
Going to try some Raxles out of a friend's B16 EF. They do look shorter than my Integra axles, so I hope this works.
Can someone give me some more info on the correct transmission fluid to use? I was using the Honda made fluid I was told was for LSD. Should I use GM Syncromesh or something else?
Old Jun 25, 2008 | 01:13 PM
Default Re: (c.dub)
Can someone give me some more info on the correct transmission fluid to use? I was using the Honda made fluid I was told was for LSD. Should I use GM Syncromesh or something else?</TD></TR></TABLE>
I used GM LSD additive with GM syncromesh back in the day and it worked great.</TD></TR></TABLE>
Old Jun 25, 2008 | 01:50 PM
c.dub's Avatar
LOL Thanks... I guess I will drain the tranny and try that stuff out.
If anyone else has suggestions/ideas please keep 'em coming.
Old Jun 26, 2008 | 10:58 AM
c.dub's Avatar
Default Re: (c.dub)
Can someone explain why GM Syncromesh is needed for a transmission like my Y1? I feel like I know what I need now, I just like to know WHY I need it, or what makes it good etc.
Old Jun 26, 2008 | 12:58 PM
Default Re: (c.dub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c.dub &raquo;</TD></TR><TR><TD CLASS="quote">Can someone explain why GM Syncromesh is needed for a transmission like my Y1? I feel like I know what I need now, I just like to know WHY I need it, or what makes it good etc.</TD></TR></TABLE>
The JDM EF Y1 gearbox has a clutch type limited slip differential. It requires special fluid because it is a clutch type differential . If you do not use the special fluid, then the differential will hop when you are turning.
The GM LSD additive is what quiets the chatter. You could use honda MTF + GM LSD additive.
Modified by red civic standard at 5:23 PM 6/26/2008
