Stripped tranny fill hole
After changing the oil in my vx MT I overtightened the fill plug and stripped the hole. I can tighten it enough to drive but dont feel confident it wont loosen and or leak. I am considering applying JB weld to the threads to seal it up permenantly. If I do, I can fill through a different spot for future oil changes. Any advice or opinions? Thanks
Modified by seeholmes at 6:32 PM 6/22/2008
My guess is that it's probably M14x1.25 or M12x1.25, but you'll want to check to make sure. If you car is a beater you can change it and then JB weld it on there, then hope that lasts the life of the car, but if it's a nice car it's probably best to buy the helicoil and spend the time fixing it right.
JASIYAH6
Mar 9, 2009 10:05 AM
