2008 civic si need HELP install V-AFC2
2008 honda civic si coupe
need wire diagram on ECM to install the V-AFC2. Does anyone have wire diagram?
or does anyone succesfully installed V-AFC2 on the new civic si? can someone help me?
Don't think it even works for the FG2. http://www.apexi.com doesn't list it as a support tool for our Civics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strikekus »</TD></TR><TR><TD CLASS="quote">2008 honda civic si coupe
or does anyone succesfully installed V-AFC2 on the new civic si? can someone help me?</TD></TR></TABLE>
no worky everyone wished it worky'd though nice try-e
Apexi V-AFC2 doesn't support FG2 is because it dicontinue before FG2 came out, however the V-AFC2 would only need IG power, Ground, RPM, Throttle signal, VTC, TDC, VTM signal, VTEC solenoid signal, and Pressure signal to work. Once these wire is connect, V-AFC2 should work. So does anyone have the ECU wire diagram?
like everyone has said it wont work but here you go if you want to try.
http://www.8thcivic.com/forums....html
i dont know about those guys but i have a neo installed in my fg2 only problem is the ecu eventually learns around all piggy backs and you have to reset every 200miles or so im trying this aem computer next
lowandslow89
Jan 19, 2007 10:11 AM
