Help with install injectors n fuel rail please
so everything but the BDL rail works- the stock rail, the stock injectors, and the 400cc injectors... you sure you have the right rail? compare the two side by side and look for attachment points, and check for differences.
also, make sure you are using a small amount of grease or vasoline on the o-rings where they insert into the rail/intake mani.
FOrSfEd
Jan 23, 2004 05:34 AM
thank you ro
