fuel rail issue's
Old Apr 12, 2007 | 10:16 PM
superhatchbackbros's Avatar
Default fuel rail issue's
im having a problem, im trying to figure out if the 390cc dsm injectors will fit into a aftermarket fuel rail, such as mr gasket ?? like where the top of the injectors sit into the fuel rail not where they go into the IM.. (THIS FUEL RAIL IS FOR BOSCH STYLE INJECTORS - YOUR INJECTORS MUST HAVE THE LARGER 14MM TYPE O-RINGS - WILL NOT WORK WITH STOCK INJECTORS) what does this mean? what does this mean? ALSO what are the stock honda 240cc injector size's? for the o-rings and crush washers, just wondering.
*if anyone has any info that can help me, please let me know asap thanks
* click here to see the rail. http://cgi.ebay.com/ebaymotors...ZWDVW
Modified by superhatchbackbros at 11:26 PM 4/12/2007
Old Apr 13, 2007 | 04:44 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
Default Re: fuel rail issue's (superhatchbackbros)
from what i can tell the "machined for bosch style" is a bigger hole. get the stock injector style for your dsms.
i just got an edelbrock rail for use with dsm 450s, and the stock machined worked perfectly. just think about it, you use the stock rail with dsm injectors...so get the aftermarket rail machined for stock injectors.
from here... http://www.injectorservices.com/injectvarious.htm
its hard to tell from the pics but...
bosch style:
honda/dsm style:
someone correct me if im wrong....
Old Apr 13, 2007 | 09:34 AM
ok so get the fuel rail ported for the stock injector.. bc ur right dsm fit in my stock fuel rail minty.. thanks
Old Apr 13, 2007 | 09:55 AM
NJcoupe's Avatar
Default Re: (superhatchbackbros)
No; the injector holes are bigger now vs the stock injectors which are smaller. you would have to have it welded shut; and then re-drilled. or create a metal sleeve to hold it into place some how.
Old Apr 13, 2007 | 10:00 AM
what injector holes are bigger? and the stock ones are smaller? my 390cc are fiting into my stock rail minty.
Old Apr 13, 2007 | 10:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superhatchbackbros &raquo;</TD></TR><TR><TD CLASS="quote">what injector holes are bigger? and the stock ones are smaller? my 390cc are fiting into my stock rail minty. </TD></TR></TABLE>
get the rail for the stock injectors if using the dsm injectors....
Old Apr 13, 2007 | 10:48 AM
ok thanks. thats all i needed to know..
Matthew98DX
Oct 31, 2016 06:28 AM
airwalk07143
Dec 30, 2008 05:56 AM
MartGSR
Jul 21, 2002 04:50 PM
