EK foglights.
Old Jun 22, 2008 | 12:15 AM
Adankid's Avatar
Default EK foglights.
So I have an EK, I just got it yesterday, I have no idea why the foglights aren't working anymore. The day I went to go look at the car, the lights turned on with no problem, today, I tried to turn them on at night, they didn't come on. I believe they are wired up. When I turn on the swith for the fogs, the little light comes on, but the fogs dont come on.
EK owners with fogs on their car, please help out a noob.
Old Jun 22, 2008 | 06:15 AM
dudeomega2000's Avatar
Default Re: EK foglights. (Adankid)
Well it could be a number of problems because the switch light does turn on. I do not think it is the relay because of that fact. There is two grounding points on the wires for the EK fogs and a plug that goes into the fuse box I would check the grounding points first if i were u. There is 1 by the driver side foglight and there is 1 underneath the panel where your switch is located. If not check the bulbs.
Old Jun 22, 2008 | 06:20 AM
97Ej6mike's Avatar
Default Re: EK foglights. (dudeomega2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dudeomega2000 &raquo;</TD></TR><TR><TD CLASS="quote">Well it could be a number of problems because the switch light does turn on. I do not think it is the relay because of that fact. There is two grounding points on the wires for the EK fogs and a plug that goes into the fuse box I would check the grounding points first if i were u. There is 1 by the driver side foglight and there is 1 underneath the panel where your switch is located. If not check the bulbs. </TD></TR></TABLE>
X2, start with the fuse, that would be a prime cause for both lights not to work.
Old Jun 22, 2008 | 06:28 AM
Default Re: EK foglights. (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
X2, start with the fuse, that would be a prime cause for both lights not to work.</TD></TR></TABLE>
Lol... yeah i forgot about the fuse as well.
SicTransitJosh
Lighting
Jun 27, 2008 03:50 AM
Jorymi
Jun 17, 2008 10:40 AM
eky2k
Sep 20, 2005 11:14 PM
dubniK
Oct 31, 2003 01:49 PM
