1 wire O2 Sensor to a 4 wire O2 Sensor HELP
Old Jul 18, 2002 | 01:29 AM
DevineCRX's Avatar
Default 1 wire O2 Sensor to a 4 wire O2 Sensor HELP
I need to add a 4 wire O2 sensor for my swap, but the stock cx harness has a 1 wire O2 Sensor. Can someone tell me how to hook this up? where to run the wires?? Its a 92 cx using cx harness. THANKS
[Modified by DevineCRX, 10:30 AM 7/18/2002]
Old Jul 18, 2002 | 02:47 AM
kenji's Avatar
Default Re: 1 wire O2 Sensor to a 4 wire O2 Sensor HELP (DevineCRX)
The easiest thing to do would be to use the appropriate engine harness for your swap.
But, if you choose to use the CX engine harness here is what you need to do.
-Cut a 4 wire O2 sensor plug off an old engine harness.
-Run 4 wires into the passenger cabin.
Here are the wire colors/locations:
yel/blk A25
org/blk A6
grn A26
wht/red D14
Good luck.
-kenji
Old Jul 18, 2002 | 07:31 AM
DevineCRX's Avatar
Default Re: 1 wire O2 Sensor to a 4 wire O2 Sensor HELP (kenji)
thanks Kenji...We needed to use the cx engine harness because the motor was JDM. Hopefully the plug for the 02 sensor is still on the JDM harness and not cut off. Do I need to run directly to the ECU, or can I run it to the plugs on the shock tower? Its a 92 cx
Drama13
Dec 28, 2012 05:47 PM
JLefevers
18
Sep 19, 2007 03:17 PM
Markb16a
May 13, 2007 08:26 PM
4d96gsr
Jan 29, 2007 10:13 PM
