B16 High Idle?
Old Jun 21, 2008 | 06:19 PM
Hookeduphatch's Avatar
Default B16 High Idle?
I have a B16a swap in my eg its idle is around 1400-1500 rpm. Is there any way to adjust the idle?
Old Jun 21, 2008 | 07:16 PM
batallic's Avatar
Default Re: B16 High Idle? (Hookeduphatch)
clean iacv, theres a screw on the back
Old Jun 21, 2008 | 07:48 PM
racerxh00's Avatar
Default Re: B16 High Idle? (batallic)
yeah take the IACV off and clean it and make sure the valve is working. just take two peices of wire and ground one and power the other to the pins and see if the valve is working. if you have a multimeter then test your wires for voltage.
Old Jun 22, 2008 | 06:22 AM
Ill try that. thanks
jdmeg61
Oct 12, 2006 07:33 PM
4ghatch
Sep 28, 2005 02:59 AM
EFin' Kyle
Sep 3, 2004 09:32 PM
HondaFanatic708
Jun 25, 2004 11:36 AM
