Problems With LS-Vtec
Right now the motor is not in the car but when it was running it had what i think was crank case pressure that was too high but im not sure all i know is that it was blowing oil past the piston rings and essentially blowing the seal between the valve caver and the head out. I want to fix the problem before i drop the motor so any suggestions would help.
