H22A engine oil cooler, nut size??
Old Jun 21, 2008 | 12:37 PM
Sproket's Avatar
Default H22A engine oil cooler, nut size??
I need to take off nut for engine oil cooler. Want to use socket, what size?
Its a 94-96 JDM H22A should be same as H22A1 for usa.
Thanks
Old Jun 21, 2008 | 07:46 PM
m00nr0ck Si's Avatar
Default Re: H22A engine oil cooler, nut size?? (Sproket)
34mm I believe
Old Jun 24, 2008 | 06:09 AM
Sproket's Avatar
Default Re: H22A engine oil cooler, nut size?? (m00nr0ck Si)
I will try that. Anyone know for sure?
Thanks
Old Jun 24, 2008 | 06:58 AM
PrecisionH23a's Avatar
It's a 27mm.
Old Jun 24, 2008 | 07:44 AM
Acidcrakker's Avatar
Default Re: H22A engine oil cooler, nut size?? (PrecisionH23a)
34mm is the size of the axel nut
Thats 2 times Ive been corrected today
Modified by Acidcrakker at 1:36 AM 6/25/2008
Old Jun 24, 2008 | 06:58 PM
TheJGB3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> AcidCrakker:34mm is the size of the axel nut </TD></TR></TABLE>
The spindle nut for the rear axle is 32MM, and the front axle nut is 36MM.
The oil cooler nut is 30MM for a 5th gen H22A4. I saw that posted on PreludePower.com for someone who had to change their oil cooler O-ring.
Modified by TheJGB3 at 8:04 PM 6/24/2008
Modified by TheJGB3 at 8:10 PM 6/24/2008
Old Jun 24, 2008 | 08:52 PM
Sproket's Avatar
Default Re: (TheJGB3)
Its a 4th gen h22a
Old Jun 24, 2008 | 09:33 PM
TheJGB3's Avatar
I would think that an H22A for a 4th gen is the same as 5th gen.
Old Jun 25, 2008 | 09:38 PM
Sproket's Avatar
I think you are right. 30mm. Im finding alot about oil cooler and 30mm
http://preludepower.com/forums...ilter
I will report back when done.
Also useful
http://www.hondaautomotivepart...AINER
Old Jul 6, 2008 | 02:04 AM
Sproket's Avatar
Default Re: (Sproket)
Its 30mm. Verified ! Thanks
kornerk12
Jul 25, 2008 05:05 PM
JDMH22AEG6
Jul 24, 2005 04:18 PM
crxste
May 21, 2003 03:04 PM
