Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Growl noise when A/C turns on.. '04 Accord EX-L - 4 cylinder ???
Old Jun 21, 2008 | 03:41 AM
elad68's Avatar
Default Growl noise when A/C turns on.. '04 Accord EX-L - 4 cylinder ???
Hello everyone,
I just noticed this last month when the weather got warm enough. Just after I start the car in the morning (and sometimes later in the day too) I hear a "growl" noise from the engine just after I turn on the A/C...Then it seems to go away. Does anyone know what this may be?
I have an '04 Accord EX-L sedan - 4 cylinder with 86,500 miles on it. I bought the 100,000 mile warranty from the dealer, so I hope this can be fixed with it.
I thought maybe it's the compressor going bad??
Anyone??
Thank you.
Old Jun 21, 2008 | 05:02 AM
msedacca's Avatar
Default Re: Growl noise when A/C turns on.. '04 Accord EX-L - 4 cylinder ??? (elad68)
Describe your growl noise. Does your engine RPMs drop when this happens like the compressor is trying to kick on? If that is the case then I think its normal, my car does the same thing and has been doing so forever I think.
Old Jun 21, 2008 | 07:34 PM
elad68's Avatar
Default Re: Growl noise when A/C turns on.. '04 Accord EX-L - 4 cylinder ??? (msedacca)
No, it's not that, and I know what you are talking about, mine has always done that too. This noise happens just after turn the car on and then put the A/C on. It's hard to describe. literally sounds like a growl like from some sort of animal. Something I've never heard before.
It's only there for a few seconds, then it's gone.
Old Jun 22, 2008 | 05:03 AM
msedacca's Avatar
I know exactly what you are talking about. Is this more likely to happen when your car is on an incline? It sounds like everything in your engine is being rattled around in its mounts? I know the sound you are describing and I've yet to figure it out.
Old Jun 28, 2008 | 07:09 PM
sun_zinc's Avatar
does this happen while idling in gear?
only two things I can think of at this point.
1. loose heat shield 2. not enough engine dampening
if it's loose heat shield, then tighten, if it's 2, replace the front engine mount. Loosen and then torque all engine mounting bolts.
Old Sep 9, 2008 | 06:39 AM
dognutz's Avatar
Default Re: Growl noise when A/C turns on.. '04 Accord EX-L - 4 cylinder ??? (sun_zinc)
I just bought an 05 accord from my uncle was grandma's car it has less than 20k and it has this same problem. Up for any more answers/ideas.
Old Sep 11, 2008 | 07:19 AM
dbbyleo's Avatar
I'm also seeing the same thing with my 05. Only has 55K and it sure seems like it "rattles" too much for its age. Sure would like to know what any of you find.
Old Sep 11, 2008 | 09:18 AM
hondaracer4vtec's Avatar
Default Re: (dbbyleo)
Usually on the heat shield might of bottomed out or a loose bolt. Happened on my old 4cyl. just ripped the heat shield off. lol
Old Sep 16, 2008 | 06:14 AM
dognutz's Avatar
Default Re: Growl noise when A/C turns on.. '04 Accord EX-L - 4 cylinder ??? (dognutz)
No, this is not a rattle on the heat shield, this is a low growl or grumble noise, it happens when it idles or the a/c is turned. It just started happening.
Old Sep 16, 2008 | 06:20 AM
Ross 2.0's Avatar
In a Junkyard near you.
Any way you can record and host the noise so we can hear it? We can guess all day...
Old Sep 18, 2008 | 05:57 PM
SFlCrx's Avatar
sounds like a tensonier. those are comon on the k24s. maybe even water pump. since you one drive belt it might sould like the noise is coming from the a/c cause you hear it more when there is extra load on it.
Old Sep 19, 2008 | 10:12 AM
dognutz's Avatar
Default Re: (SFlCrx)
Is there a way to check the tensioner or do you just replace it.
Old Sep 19, 2008 | 06:03 PM
SFlCrx's Avatar
put an screw driver on it and listen also there is a mark on it. find it and take a picture and post it.
Old Sep 21, 2008 | 09:22 AM
CBL9's Avatar
My 06 has been doing this for as long as I can remember, I bought it with 9 miles on it, and now it has 30,xxx. I think it is simply the sound of the compressor kicking on.
Old Sep 28, 2008 | 09:55 AM
dhtGSR's Avatar
Default Re: (CBL9)
I had a similar problem with my GSR. Initially, there was a screeching sound that lasted about 5-10 sec when I first turned on the a/c - usually in the mornings. The screeching progressively got worse to the point where people would look around at stoplights...lol.
Turned out in my case that the radiator fan motor bearings were toast. If the noise only comes on when your compressor clutch engages or when you're idling at a stoplight, you might want to check the fan motor first. It's quite easy to check/confirm - just remove the fan connector and turn on the a/c.
Good luck.
Accordpmk
Honda Accord (2013 - 2015)
Sep 10, 2017 02:46 PM
fljmruiz
Mar 26, 2014 06:56 AM
mfiazzo
Oct 8, 2013 05:13 AM
k3lvin_08
26
Aug 11, 2013 05:50 AM
oj5joker
Nov 11, 2008 05:17 AM
