Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2008 Accord - cold engine start noise
Old 07-29-2013, 05:25 PM
k3lvin_08's Avatar
Default 2008 Accord - cold engine start noise
I have a honda accord 08 with 70 miles the car makes a noise only on cold start i don't know what cause this noise but I think its not normal. I would like to know if somebody knows about this problem. Thanks
Old 07-30-2013, 01:50 PM
Old Member
GoLowDrew's Avatar
Default Re: 2008 Accord - cold engine start noise
Like what? Describe the noise. More info. Maybe a video?
Old 07-30-2013, 02:07 PM
My Name is Nobody
MSchu's Avatar
@ 70 miles you should be worried...
post or describe please.
Old 08-02-2013, 06:02 AM
Steve@Spreen's Avatar
Probably 70k.... V-6? If the noise goes away when the vehicle warms up...probably the return hose o-ring on the power steering pump. Pt # 91345-RDA-A01. Easy fix. Other than that, like previous stated, more info needed.
Old 08-02-2013, 08:24 AM
HatchVX's Avatar
My guess is that its a 4 cylinder. If so what you are hearing is the VTC actuator. It will need to be replaced. Look at Service bulletine 09-010.
Old 08-02-2013, 02:11 PM
Lost Again's Avatar
X2 ^......but some of the v6 had a sim issue.
Old 08-02-2013, 02:50 PM
Global Moderator
tech8's Avatar
V6 didn't have VTC -Variable Valve Timing Control; so, it would not be a similar issue for a V6.
Old 08-02-2013, 03:45 PM
Lost Again's Avatar
The v6 do have vtec but then they also have VCM....or am I getting my 07 Pilot confused with the Accord......could be
Old 08-02-2013, 04:14 PM
My Name is Nobody
MSchu's Avatar
you're both somewhat not completely correct. the 6 speeds had NO VCM and DID have vtec.
Old 08-02-2013, 04:21 PM
Global Moderator
tech8's Avatar
VTC is not exactly the same as VTEC.
On Honda’s K series (4 cylinder engines), i-VTEC system adds VTC (Variable Timing Control) to VTEC to provide continuously variable camshaft timing . It is a different concept of variable valve timing. For the K series, i-VTEC is a combination of VTEC and VTC.
i-VTEC is intelligent-VTEC.
VTC and VCM are different animals.
While the 8th generation Accord V6 (J series engine) had what Honda terms i-VTEC (intelligent-VTEC), it does not have VTC. Certain 8th generation Accord V6 had i-VTEC with VCM. VCM is Variable Cylinder Management. Depending on the driving conditions, the Accord V6 can go from 6 cylinders, to 4 or 3 cylinders for fuel economy.
Old 08-02-2013, 04:22 PM
Global Moderator
tech8's Avatar
I did not state the V6 didn't have vtec.
Old 08-05-2013, 03:26 PM
k3lvin_08's Avatar
my car is a "4 cylinder engines" but I am not sure what i have to fix because I have seen different comments.
in this link you guys can see how is the noise.
Old 08-05-2013, 04:03 PM
shrekfiona's Avatar
My car used to make the same sound Steve@Spreen mentioned above. It was a V6 as well. The noise used to be so loud that you could hear it in the room above the garage. After 10 miles when the car warmed up the rattling was gone. The noise disappeared completely even on a cold start when the warranty recall of power steering hose was done.
Old 08-05-2013, 05:29 PM
My Name is Nobody
MSchu's Avatar
you DID say the v6 had VCM... that is not entirely true.
that sound is almost like the engine is Dieseling just after start up OP... like the plugs are pre igniting the mixture. what did the dealer say?
Old 08-05-2013, 06:10 PM
HatchVX's Avatar
That is is the VTC actuator. Im a honda tech and have done MANY of these.
Old 08-06-2013, 06:51 AM
He stated it correctly, certain V6s do have VCM, he didn't say all
OP, I believe HatchVX is correct, we have replaced a few of these here as well.
Old 08-06-2013, 08:06 AM
My Name is Nobody
MSchu's Avatar
are you sure... I am.
the original statement stands... both those knuckleheads were not ENTIRELY correct.
Old 08-06-2013, 09:44 AM
Global Moderator
tech8's Avatar
Re-read my posts, I never stated all V6 had VCM, I stated certain V6, which Steve@Spreen pointed out. You're the knucklehead here regarding my posts.
Old 08-06-2013, 09:56 AM
Global Moderator
tech8's Avatar
You've been misstating things in several of your posts.
Old 08-06-2013, 10:57 AM
Getting a little OT here guys....MSchu, both posts never stated "all" Tech 8 said certain, and Lost Again hedged his comment stating that he was speaking from his personal experience with his Pilot.
Guys play nice, don't make me pull this car over
K3lvin_08, any progress?
Old 08-06-2013, 01:19 PM
BLKFLSH's Avatar
So do any of you Einstein's know how to fix the actuators? How difficult is it? I don't think the OP gives a crap what V6 engines have VCM.
Old 08-06-2013, 01:49 PM
Global Moderator
tech8's Avatar
It may have already been posted before on this forum.
Here is Honda TSB A09-010 and a related Honda Tech2Tech video. I zipped the TSB as it wouldn't upload the latest pdf.
File Type: zip
Old 08-06-2013, 05:12 PM
BLKFLSH's Avatar
That looks like fun. I didn't notice any special tools, besides needing an air compressor for one part. I guess you could do it yourself.
Old 08-06-2013, 05:29 PM
HatchVX's Avatar
Follow this video http://cms.skunk2.com/id/377/
It helps with the swap.
Old 08-07-2013, 03:43 PM
k3lvin_08's Avatar
I have been reading your comments and I think the way for to fix that is replacing the VTC actuator...
Quick Reply: 2008 Accord - cold engine start noise
