Southern California Fresno & Below
anyone with a clutch Alignment Tool ?
Old Jun 20, 2008 | 09:37 PM
949's Avatar
949
Default anyone with a clutch Alignment Tool ?
i need to borrow the little tool that lets you align the clutch when installing a new clutch.
i have the exedy clutch. not sure if that matter.
ef 91 civic manual.
im located in socal. need to borrow it asap.
thanks.
Old Jun 21, 2008 | 01:00 AM
civichb20's Avatar
PM Garage
Default Re: anyone with a clutch Alignment Tool ? (949)
you can buy at local auto shop for cheap and excedy should have came with one good luck
Old Jun 21, 2008 | 07:18 AM
949's Avatar
949
yeah it did. at the time, i had it installed at a local shop. they tossed it, i didnt think i was going to need it again. so i didnt ask for it either. oh well stupid me.
i was curious. if i dont align it up with the tool will i be able to still get the tranny hooked up to the block still?
the reason i ask is i didnt remember about the alignment tool and i have been trying to install the tranny to the block. it will mate up sometimes and when it does the clutch arm wont move. i am hoping its just the alignment. the only other thing i can think of is that i did just change out the throwout bearing and i hope its the correct one. the new throw out bearing looks kinda of different from the old one. im just assuming its cause the manufacturer is different. it does look very similiar but the inner center part is just a tad bit shorter then the oem one i have.
i did double check the place i ordered it from to make sure but who knows.
here is a pic.
they look almost the same but very very slightly different.
Modified by 949 at 8:30 AM 6/21/2008
Old Jun 21, 2008 | 04:38 PM
OEM-'s Avatar
no it wont line up! you NEED that tool! UNLESS you are REALLY PRO and can do it with your finger by feeling on it, but i doubt that.
Old Jun 22, 2008 | 06:51 PM
Didly's Avatar
I've done it with out the tooll but its a pain in the ***.. and the engine was out of the car..
Go to autozone.. they will lend you one if your not an ******* to them.
just bring your clutch in with you to get the right one...
Old Jun 22, 2008 | 11:31 PM
ieatrice's Avatar
it's like $3 at ur local car parts store. if u really need one, i have one u can borrow. PM me!
Old Jun 25, 2008 | 10:30 AM
949's Avatar
949
hey thanks. did get to borrow one so im good now.
Silent9o8
Nov 8, 2006 01:56 PM
RTW DC2R
Feb 11, 2005 04:37 PM
fastlude69
Jul 14, 2004 07:12 PM
FwdCivicHatch
Apr 22, 2004 08:11 AM
daver
Jul 31, 2002 05:24 AM
