Someone know if I need to remove the dash to change the A/C expansion Valve??
Old Jun 20, 2008 | 06:00 PM
Dary Type S's Avatar
New User
Default Someone know if I need to remove the dash to change the A/C expansion Valve??
Please help me .....
Old Jun 20, 2008 | 07:57 PM
skuded's Avatar
Default Re: Someone know if I need to remove the dash to change the A/C expansion Valve?? (Dary Type S)
you shouldnt have to, if its not bolted to the firewall, then its inside next to the evaporator core, all you have to do is pull the hvac box out under the passenger side dash, you do not have to remove the dash, however its a pain in the ***. whats your proublem by the way?
Old Jun 21, 2008 | 07:56 AM
New User
My problem is that my rsx-S damage the air compressor and the technician recommended me to change the expansion valve and the bottle filter.
Old Jun 21, 2008 | 08:05 PM
skuded's Avatar
so your ac compressor went out and the tech is recommending that you replace the expansion valve, and reciever drier, you could get away with just flushing the condensor and evaperator and all lines, with a good flush you shouldnt have to replace the expansion valve, just depends on the shop you take it to, its easy to flush everything.
jtdunn4life
Honda CR-V & Element
Apr 24, 2019 09:10 AM
DeepSeaPapa
Honda Civic (2006 - 2015)
May 25, 2018 12:33 PM
averyvm
Jun 16, 2009 10:00 AM
schtozo
Jun 24, 2007 11:54 PM
[ iLL ] iNt3GrA
May 23, 2004 05:33 PM
