Takata harness in a civic coupe?
Old Jun 20, 2008 | 04:19 PM
pliskin8's Avatar
Default Takata harness in a civic coupe?
this guy is selling a takata 4 point harness brand new! the only problem is that it's the short version [for a 2 seater car] and i have a 97 civic coupe, does anyone know if i would still be able to install it? and how or what else i would need.
Old Jun 20, 2008 | 04:45 PM
dumafit's Avatar
Default Re: Takata harness in a civic coupe? (pliskin8)
yes you can strap it to a harness bar
Old Jun 21, 2008 | 02:26 PM
Shizfish's Avatar
You should be mounting your harnesses to a harness bar anyway. When the harnesses are mountd to the floor, and you get into an accident, the tension force of the harness is pullign your shoulders down, which compresses your spine and could cause serious injury. There's a reason why racetracks have regulations for the mounting of a harness. If you even just loop it over a bar directly behind the seat, and to the ground, the tension force is pulling back, not down. So as long as you have a bar, yes. If not, you might wind up being in a wheel chair for the rest of your life. Just thought I'd throw some info out there in case you weren't aware, because most people have no clue that harnesses mounted to the floor is a serious hazard.
Old Jun 21, 2008 | 04:33 PM
pliskin8's Avatar
Default Re: Takata harness in a civic coupe? (Shizfish)
thanks 4 the info!
Old Jun 21, 2008 | 04:37 PM
Lazysk8r2's Avatar
you can mount it to the rear seat belts like as shown on the takata website
Old Jun 21, 2008 | 04:47 PM
themikewoo's Avatar
Anyone know where you can purchase the bar?
Old Jun 21, 2008 | 05:08 PM
pliskin8's Avatar
Default Re: (themikewoo)
i've been looking around and found them at http://www.corsportusa.com/ they are the sparco ones and sell for $400. its the only place i've found them so far
Old Jun 21, 2008 | 05:20 PM
themikewoo's Avatar
Sweet removable! Anyone have pictures installed?
Modified by themikewoo at 8:01 PM 6/21/2008
Old Jun 21, 2008 | 05:24 PM
EJ8 944's Avatar
i think this is probably the most affordable bar availible, its what i plan to use
https://honda-tech.com/zerothread/1592059
94allmotor
Jun 1, 2012 10:47 AM
thehatchninja
10
Mar 22, 2005 08:30 PM
Pythagoras
17
Sep 3, 2004 07:23 AM
275Performance
17
Apr 22, 2004 01:35 PM
Powered by Honda
15
Mar 5, 2004 06:54 AM
