Whats a good clutch?
Well, my clutch is completely gone now on my del sol. I have a d15b7 motor and i want to know whats a good brand clutch that is cheap and reasonable for daily driving? Im looking for a clutch that can last me along time and that can handle minor bolt ons later on? And what else would i need besides a flywheel and clutch? Should i also change my throw out bearing as well? Alright thanks.
Thanks everyone, exedy it is! But now i need your help again because, my wheel lock is stuck on my studs. Like when i try to turn the wheel lock, the stud is moving as wells. And now i cant remove the wheel lock. Does anyone know any solution to my problem? I dont know how to stop the stud from spinning while i try to remove the wheel lock!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">Exedy FTW:
http://www.autopartswarehouse.....html</TD></TR></TABLE>
i'm not too sure about that...
https://honda-tech.com/zerothread/2381058
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdriverzero1 »</TD></TR><TR><TD CLASS="quote">i would just spin the whole stud out throw the stud in a vice and get the wheel lock off and then slap the stud back in. 1 extra step but easier to work with off the car ya know?</TD></TR></TABLE>
How is the stud going to come out of the hub?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyDelS0l »</TD></TR><TR><TD CLASS="quote">Thanks everyone, exedy it is! But now i need your help again because, my wheel lock is stuck on my studs. Like when i try to turn the wheel lock, the stud is moving as wells. And now i cant remove the wheel lock. Does anyone know any solution to my problem? I dont know how to stop the stud from spinning while i try to remove the wheel lock! </TD></TR></TABLE>
I'd drill a large hole in the stud and tap on the wheel lock with a hammer to snap the stud. If it doesn't snap easy, drill a bigger hole. You may need a new hub if the stud stripped it out while spinning. It's more likely that the stud stripped but you never know. If the hub seems good after you put a new one in, I'd still spot weld the head of the stud to the hub (like you do with extended studs).
Muydos
Apr 6, 2012 05:30 PM
