hks ssqv not holding boost
Old Jun 20, 2008 | 01:42 AM
anton_'s Avatar
Default hks ssqv not holding boost
i have the 1st gen ssqv bov and i am boosting 23 psi the bov starts to flutter when the boost come, at 16 psi its working well. i have a large vacuum line from the trottlebody. the bolt on the bov is almost drawn to the bottom,
cant the ssqv handle high boost?
Old Jun 23, 2008 | 10:00 PM
transpro's Avatar
Default Re: hks ssqv not holding boost (anton_)
hole in the diaphragm, or leak somewhere check it out with a compressor.
Old Jun 24, 2008 | 05:41 AM
HiProfile's Avatar
Default Re: hks ssqv not holding boost (transpro)
Thats probably the case, since its a pull-style valve. Boost pushes it closed tighter, not pushing it open like other BOV's. It could also the seal around the valve's shaft, as pressure there woulds start to push the diaphragm, and pressure at that side would open the valve.
Old Jun 24, 2008 | 09:21 AM
transpro's Avatar
Default Re: hks ssqv not holding boost (HiProfile)
Yup, it is probably opening and closing because of air going through the diaphragm is pushing on the other side of the diaphragm
Synapse
Sep 17, 2006 08:27 PM
95excoupe
May 29, 2004 07:40 AM
pipes
Feb 19, 2004 05:21 PM
PUREVIL
May 20, 2003 09:13 PM
Smoothy
Nov 14, 2001 08:48 PM
