Will b16a pistons fit into a b18a
Old Jul 17, 2002 | 09:19 PM
moonski93@aol.com's Avatar
Default Will b16a pistons fit into a b18a
i putting together an ls vetc i have eagle rods and total seal pistons im not to sure but r the b16a pistons smaller in bore size ?and can i use the piston rings that came on the b16a since i pulled apart the short block if i needed to
Old Jul 17, 2002 | 09:21 PM
89 CRX SI's Avatar
Default Re: Will b16a pistons fit into a b18a (moonski93@aol.com)
hit new topic next time not new polllll..... nE ways the b16 pistons are for a 1.6L engine the b18a arre for a 1.8L engine.
.2L differrence your rings will fit easily tho...........
Old Jul 17, 2002 | 09:51 PM
big pete's Avatar
Default Re: Will b16a pistons fit into a b18a (89 CRX SI)
the bore on all bseries the same (except the b20)
Old Jul 17, 2002 | 10:21 PM
EF'n Fast's Avatar
Default Re: Will b16a pistons fit into a b18a (big pete)
There...now the poll is functional.
Old Jul 17, 2002 | 10:46 PM
Bleed Black's Avatar
Default Re: Will b16a pistons fit into a b18a (EF'n Fast)
Yeah, and you get the advantages of higher compression.
Old Jul 18, 2002 | 07:25 PM
pelotudo's Avatar
Isn't it supposed to be
"Smoke weed everyday?"
If you're going to be a tard...do it right.
jB
Old Jul 18, 2002 | 07:29 PM
rioninja's Avatar
In answer to your question, YES the B16a pistons will fit right onto B18a/b rods and vice versa.
In fact, i currently have B18a pistons in my B16a right now for my turbo setup.
hbyrd8701
Mar 1, 2010 05:55 AM
boostcrx91
May 27, 2007 11:48 AM
AdoRe
Oct 18, 2006 08:52 AM
filetofit
Oct 3, 2002 01:22 PM
hopelessrex
Jun 20, 2001 07:28 PM
