what do i need for my turbo
ok i just baught a Air research (garetts top model) T3 just the tubro alone and i need to know what else do i need to complete the turbo kit please help and be specific
turbo manifold
downtube/dump pipe
wastegate
blow off valve
oil lines-feed/drain
charge pipe
intercooler
larger injectors(depending on where you get them from possibly a resistor box)
and a good TUNE
thats pretty much the basics, and that all depends on what you plan on doing internally to your mtor
if your going to build your own turbo kit you really should have done the research before you even bought the turbo
downtube/dump pipe
wastegate
blow off valve
charge pipe
intercooler
and a good TUNE
i agree with the last guy, you should have looked at the forced induction forum before buying the turbo....
anyway, the list this guy gave you is the essential stuff... if you plan on running a lot of boost get a 3 bar map sensor and you will want to get gauges like boost and air fuel ratio... so you know whats going on... also will need vacuum lines
DO NOT FORGET A GOOD TUNE!
about the injectors a good bet would be dsm injectors from a talon or eclipse...next bet AEM!!! but its what I'm using for a b18c1. what motor do you have is another big thing. but for sure what the first post was.
well i got it realy cheap it came with the wastegate and turbo and i got it for 50 and call of duty 4 for 360 hahah yah and whats the resistor box for like what brand do i need
The first three links in the first post in this forum leads to 98% of the info you need to build your turbo kit. The other 2% is basicly stuff the tuner needs to know, or oddball crap like turbo oil feed restrictors.
Seriously, if you are in ANY way serious about turbocharging, go searching for info. Don't ask to be spoon-fed, especially not with a question that can AND HAS BEEN answered with entire VOLUMES of books.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supaf1y »</TD></TR><TR><TD CLASS="quote">well i got it realy cheap it came with the wastegate and turbo and i got it for 50 and call of duty 4 for 360 hahah yah and whats the resistor box for like what brand do i need</TD></TR></TABLE>
Omg....you've got to be kidding me
You should really not take part in turbocharging anything until you do a lot more research. This is ridiculous...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">The first three links in the first post in this forum leads to 98% of the info you need to build your turbo kit. The other 2% is basicly stuff the tuner needs to know, or oddball crap like turbo oil feed restrictors.
x2...Search the FAQ at the top of the Forum and you will find all the answers you need.
</TD></TR></TABLE>x2...Search the FAQ at the top of the Forum and you will find all the answers you need.
stevn
Jan 15, 2009 02:31 PM
