car dies when i give it gas..HELP
Old Jun 19, 2008 | 04:47 PM
MI4$DC5's Avatar
Default car dies when i give it gas..HELP
94 EG
B16a2
NO CELs
Swapped in b16. cranked her up and she idles perfectly, but when i give it gas i she revs to 2-3k and dies out. The dizzy is brand new so are the plugs. As soon as i tap the gas she starts boggin and if i keep my foot on the gas she dies out completely. Timing is on. anyone out there have this problem before?
Old Jun 19, 2008 | 05:03 PM
racerxh00's Avatar
Default Re: car dies when i give it gas..HELP (MI4$DC5)
check for vacuum leaks.
especially around the throttle body.
Old Jun 19, 2008 | 05:18 PM
MI4$DC5's Avatar
Default Re: car dies when i give it gas..HELP (racerxh00)
alrightty im going to check for leaks right now..i did that already but i will double check
Old Jun 19, 2008 | 05:31 PM
MI4$DC5's Avatar
just checked for leaks and i have no leaks...i even tried swapping the MAP and TPS but that didnt work either. Could it my fuel pump. i mean the car starts and idles fine, its just when i give it gas it dies out like its not getting any fuel
Old Jun 19, 2008 | 05:41 PM
tortis's Avatar
i guess you checked the fuel filter.
Old Jun 19, 2008 | 05:45 PM
z6hatchboy's Avatar
If your sure the timing is right, then check the fuel filter as mentioned above. A lot of the time that is the problem, its lets enough flow for a idle but is so clogged it can supply enough fuel above idle.
Old Jun 19, 2008 | 06:21 PM
MI4$DC5's Avatar
Default Re: (z6hatchboy)
i put a new fuel filter in, but let me double check..
Old Jun 19, 2008 | 06:58 PM
MI4$DC5's Avatar
Default Re: (MI4$DC5)
fuel filter is new..anything else
Old Jun 19, 2008 | 07:08 PM
z6hatchboy's Avatar
when you change tps's you have to calibrate them its some lie .45v closed and 5v open i think.
Old Jun 19, 2008 | 07:11 PM
MI4$DC5's Avatar
alrighty im going to check that
Old Jun 19, 2008 | 07:28 PM
MI4$DC5's Avatar
dam TPS is good...man im freaking stumped like a ****...i guess my next move would be to get another fuel pump?
Old Jun 19, 2008 | 08:36 PM
One Day H23's Avatar
check for cracks in the air intake. (pgi-fi?) also. you may have a clogged injector, or ones not working. what do you mean it dies? when you punch it and let off does it go back to idle? if its that check you dizzy timing!
Old Jun 20, 2008 | 04:24 AM
MI4$DC5's Avatar
Default Re: (One Day H23)
no i mean, when i cut the car on it starts up and idles fine. But when i give it gas once it hits around 2500-3k rpms if i leave my foot on the gas it cuts off, but if i let off while its bogging and choking then she goes back to idle. She idles all day.
Old Jun 20, 2008 | 08:27 AM
MI4$DC5's Avatar
anymore suggestions
Old Jun 20, 2008 | 09:32 AM
92 CIVIC 4DR's Avatar
my d15b swap on my 4door usto do that Until i open the throttle body more to breath more air its a flat screwdriver and give it more air man it needs to breath! you will see it right on the air throttle body man :-) 4 reals!
Old Jun 20, 2008 | 09:38 AM
cehcivic15's Avatar
Default Re: car dies when i give it gas..HELP (92 CIVIC 4DR)
ok nevermind lol
Old Jun 20, 2008 | 09:40 AM
It could be what he said^ but when i switched mine my engine started to jump like a **** lol
Old Jun 20, 2008 | 11:49 AM
MI4$DC5's Avatar
dam im ready to shoot this ****
Old Jun 20, 2008 | 05:50 PM
jeremyf76's Avatar
Sounds like im having almost the exact same problem Only difference may be That sometimes I can pump the gas pedal and it starts taking gas but something aint right. Please let me know if and when you figure it out. I will do the same if I figure it out. Oh by the way, a mechanic said it sounded like a weak fuel pump but I havnt followed up on it and tested it yet. Later
Old Jun 20, 2008 | 06:40 PM
MI4$DC5's Avatar
Default Re: (jeremyf76)
yeah thats what my mechanic said. im going to buy a fuel pump and try that out
Old Jun 20, 2008 | 07:02 PM
jeremyf76's Avatar
Ok, let me know how it goes
Old Jun 20, 2008 | 09:30 PM
Azelas's Avatar
Just a wild guess, but if the pump doesn't do it, try hittin the gas with your
exhaust manifold off.
Old Jun 21, 2008 | 04:01 AM
MI4$DC5's Avatar
Default Re: (Azelas)
hmmmmm. give it gas without the exhaust manifold on? if that works what does that mean?
Old Jun 21, 2008 | 10:15 AM
T_Blaze's Avatar
plugged cat
Old Jun 22, 2008 | 04:20 PM
Default Re: (T_Blaze)
if he had a clogged cat, the car wouldnt have no power. im thinking theres a vaccum line in the wrong spot, or off. Fuel injectors would do that also. but if it were FI's then it would run rough idling also. worth a try taking the manifold off.
