ITR Seats
Old Jun 19, 2008 | 04:46 PM
Abius's Avatar
Default ITR Seats
There was a topic in here about taking ITR seats and putting them into an EK. He said that they were not bolt on. He did a DIY on how to put the ITR seats int he EK. Had to take off uphostry on the seats and put them on the EK frame.
ANyone have a link to this topic, and would it work with EG seats?
Thanks
Old Jun 19, 2008 | 04:50 PM
geneeunit's Avatar
Default Re: ITR Seats (Abius)
fronts or rears? or both?
fronts i believe you just swap out the seat rails, and the rears im not positive about on the 92-95 civics. is it a hatch, coupe, sedan?
Modified by geneeunit at 5:58 PM 6/19/2008
Old Jun 19, 2008 | 05:38 PM
Abius's Avatar
Default Re: ITR Seats (geneeunit)
Sorry
It is the rears. In the original post its the EK hatchback
Old Jun 19, 2008 | 08:29 PM
BlueIntegraBoy's Avatar
https://honda-tech.com/zerothread/2196363
Old Jun 20, 2008 | 11:41 AM
Abius's Avatar
Default Re: ITR Seats (BlueIntegraBoy)
Im guessing it would work the same for an EG
Old Jun 20, 2008 | 11:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Abius &raquo;</TD></TR><TR><TD CLASS="quote">Im guessing it would work the same for an EG</TD></TR></TABLE>
Nope, the backrests bolt up right into a 92-95 Civic HB. I had them in my old hatch.
Old Jun 21, 2008 | 05:43 PM
Abius's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
YES, the backrests bolt up right into a 92-95 Civic HB. I had them in my old hatch.</TD></TR></TABLE>
Fixed?
I have a 93 Civic HB
Dunno I find your contradicting yourself?
To get answer I need, simple questions.
Will Type-R rear seats fit in my EG either by modding them like in other Topic, or they will just bolt right in?
Old Jun 22, 2008 | 01:47 PM
Abius's Avatar
Bump!
Old Jun 22, 2008 | 01:50 PM
Fixed?
Will Type-R rear seats fit in my EG either by modding them like in other Topic, or they will just bolt right in?</TD></TR></TABLE>
Haha, my bad. I don't know what I was thinking.
The ITR backrests do you bolt fine without mod into a 92-95 hatch
Old Jun 22, 2008 | 04:30 PM
Abius's Avatar
Cool alright thanks
Old Jun 22, 2008 | 04:43 PM
ts eg6's Avatar
to make them fit in the rear you need the two door top and four door bottom seats so you wont have any gaps or else if you use the two door bottom you will have gaps
Old Jun 22, 2008 | 05:05 PM
turboteg90's Avatar
pm for noodz
Default Re: ITR Seats (ts eg6)
i got them in my eg hacth
Old Jun 23, 2008 | 07:07 AM
Abius's Avatar
So your telling me if I take just DC2 rear seats and put them into my EG h/b, there will be a gap?
Could I not fix this by removing the frames from the cusions and using the stock frames. JUst like in the topic mentioned before.
Old Jun 23, 2008 | 08:39 AM
Mashimaro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Abius &raquo;</TD></TR><TR><TD CLASS="quote">So your telling me if I take just DC2 rear seats and put them into my EG h/b, there will be a gap?
Could I not fix this by removing the frames from the cusions and using the stock frames. JUst like in the topic mentioned before.</TD></TR></TABLE>
there will be a gap between the bottom of the backs and lower bench portion.
i'm not sure if you could just re-wrap the EG seats with the ITR covers. the ITR (usdm) has a plastic tray in the middle of bench.
search long and hard to find yourself the ITR 4-door bottom.
here's a pic of mine with the 2-door tops, and 4-door bottom:
Old Jun 23, 2008 | 09:16 AM
Abius's Avatar
Default Re: ITR Seats (Mashimaro)
Hmm, but the guy in this Topic did the same just with his EK
jbubsdc5
Feb 12, 2009 10:43 AM
WABoostedb16
Aug 6, 2008 05:10 PM
SiRlos
Jun 18, 2008 09:15 AM
Punker1234
Aug 21, 2005 11:22 AM
cornholioEK
14
Jul 18, 2003 07:50 AM
