Smoking bad (any hints)
Old Jun 19, 2008 | 02:26 PM
streetcartuner's Avatar
Default Smoking bad (any hints)
i over heated the motor really bad once and drove it like that for like 10 miles
the needle wasw past H
the bottom rad hose came off the block
i already replaced the head gasket,deck milled the head, and replaced the water pump
im starting to wonder if i warped the cylinder wall and or if a maybe cracked a piston ring
let me know if anyone has had this happen to them
thanxs
and save all ur cocky comments i needed to get it home i wasnt leaving it on the side of the highway
Old Jun 19, 2008 | 02:27 PM
Default Re: Smoking bad (streetcartuner)
oo ps its a B18C1
Old Jun 19, 2008 | 02:50 PM
freshdaily's Avatar
what color smoke?? white?? blue/gray??
Old Jun 19, 2008 | 04:13 PM
tortis's Avatar
Default Re: Smoking bad (freshdaily)
my guess is a warped head
Old Jun 19, 2008 | 04:49 PM
elektronsi's Avatar
Default Re: Smoking bad (tortis)
like freshdaily said, what color is the smoke, that can atleastp point us in the right direction
Old Jun 19, 2008 | 06:49 PM
Default Re: Smoking bad (elektronsi)
ok i fixed the head gasket problem i got it milled but it smokes a blackish gary color
oil im guessing
what could i do to fix this
Old Jun 19, 2008 | 07:13 PM
elektronsi's Avatar
oil would produce blue smoke, sounds like your running rich
white-coolant in cylinder(s)
blue-oil in cylinders
black-too much fuel
Old Jun 19, 2008 | 07:41 PM
blkegcoupe's Avatar
From: ....................................................................................................
why would you drive it for 10 miles?
TehTaylor
Feb 11, 2012 04:00 PM
EKferio 808
May 9, 2010 10:15 PM
mikeSMASHES
Mar 6, 2010 09:37 PM
tunerauti
Jun 6, 2008 12:26 PM
crx si 2004
Aug 2, 2004 07:47 PM
