First time to the track tomorrow... Any suggestions?
Old Jun 19, 2008 | 12:45 PM
Momentum's Avatar
Default First time to the track tomorrow... Any suggestions?
Alright so tomorrow night will be my first time taking my EG Hatch out to the track...never done the 1/4 mile before so im looking for any suggestions at all! Launch suggestions, any techniques, what did you guys struggle with your first few times out? Best way to improve my time? Also with this setup what should i be launching at? Kinda dissapoitned i wasnt able to get some better tires before i went... Oh well maybe by next week.
Engine
B16 head
Skunk2 stage 2 cams
BDL cam gears
Omni power springs
Omni power retainers
ARP head studs
ABES intake manifold
Thermal Intake manifold gasket
RC 310 injectors
Chipped ECU with data logging
I think that’s it??
LS block
Fresh honed
New OEM P30 pistons (11.7:1~ compression)
New OEM Oil pump GSR
New OEM Water pump GSR
ARP Rod bolts
Integra Type R transmission 97 spec LSD
Exedy Stage 1 organic clutch
Breathing/Cooling
Megan Racing header
2.25 exhaust (no cat)
Intake system
GSR radiator
Any feedback appreciated!
Also, any idea what i SHOULD be able to run with this setup?
Old Jun 19, 2008 | 01:16 PM
speeddave's Avatar
Default Re: First time to the track tomorrow... Any suggestions? (Momentum)
too bad i am gone this wknd! i would love to be out there tommorow. i went last fri and broke my tps sensor( my edelbrock mani is a tight fit in the EF bay ) only got 1/2 a run in, haha.
as far as your setup goes, there's way to many variables to say what times you will run... alot depends on the tires, and it sounds like your just on streets.
i say air them down a bit, drive around the burnout box and play with your launch rpm. pre-loading with the ebrake is the best way to launch imo.
good luck!
Old Jun 19, 2008 | 01:36 PM
Momentum's Avatar
Default Re: First time to the track tomorrow... Any suggestions? (speeddave)
What PSI should i run the tires at? Shitty federal tires... bad tread
Old Jun 19, 2008 | 01:47 PM
speeddave's Avatar
what psi do you run them at normally? from a guess standpoint as i dont have any experience with running street tires, i would say 20-25psi. start high and work your way down to see if your times/traction improve. dont go too low as your tire will start to cup.
old school way to see if your contact patch is good is to lay a patch on some pavement. then inspect the marks, heavy black down the center is too much psi, and two lines with nothing down the center is too low psi. you want it black all the way across
Old Jun 19, 2008 | 02:11 PM
SovXietday's Avatar
This is coming from someone who has seen it happen many times first hand.
For your first time out, just go out and enjoy the experience... and don't stall the car.
You won't be cutting your best times so don't get dissappointed with your higher than expected times. Happens/ed to all of us.
Old Jun 19, 2008 | 09:50 PM
Momentum's Avatar
Yeah i just did a couple quick launches, anything over 3k i spin... even at 3k a little spinning.
Old Jun 20, 2008 | 12:27 AM
A.E Motoring's Avatar
Default Re: (Momentum)
practice practice, try to invest into some BFG drag radial
Old Jun 21, 2008 | 06:05 AM
Momentum's Avatar
So i ran about 7 or 8 times last night...
First run: 16.4
Second: 15.6
Third: 15.3
Best: 15.23
After my third run of 15.3 i had 4 others between 15.3 and 15.4.
Even on my best run i spun for [freak]ing ever... Cant wait to get some new tires and go back next week! I see no reason why I cant make 14s... i was so close on my first night going!
Old Jun 21, 2008 | 06:24 AM
Momentum's Avatar
between 90 and 92.5
Old Jun 21, 2008 | 07:04 AM
Momentum's Avatar
Its actually tuned with crome.
I can tell it is running a liiiitle rich though.
Old Jun 21, 2008 | 07:08 AM
Momentum's Avatar
Not sure... this was done before I owned it.
Old Jun 21, 2008 | 08:21 AM
nsxmatt's Avatar
Default Re: (rota92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm not an all motor guy but the MPH seems slow</TD></TR></TABLE>
Your right, that's I/H/E Z6 in a hatch type of times and mph. Wayyy off of a built ls/vtec.
Old Jun 21, 2008 | 04:50 PM
Momentum's Avatar
Default Re: (nsxmatt)
Here is my slip... maybe you can find my problem?
R/T: .275
60': 2.358
330: 6.523
1/8: 9.929
MPH: 72.66
1000: 12.830
1/4: 15.286
MPH: 92.26
Old Jun 21, 2008 | 06:32 PM
SovXietday's Avatar
60' is way slow, but it looks like your car is not making the power it should. Definitely not actually.
Get that **** tuned.
Old Jun 21, 2008 | 10:24 PM
harmonator84's Avatar
Default Re: (SovXietday)
Yea I just got back from the drag races. You should be running much better then that.
The track I went to was just a 8th mile. I will have to go back and look at my slips to see what my best time was...but I do know my 60' was better then what your showing...
Oh I just have a stock b18a in a crx.
If I was you I would prob check on getting a new tune!
Old Jun 23, 2008 | 10:49 AM
Momentum's Avatar
Did a compression test today... 220 all the way across
Old Jun 23, 2008 | 12:11 PM
nick lsvtec's Avatar
get it tuned.my completely stock ls/vtec in a eg hatch went 14.8.stock exhaust and stock p28.first time at the track.i ran a 14.8 taking off normal because i was on bald tires.i was running 91-92mph.
Old Jun 23, 2008 | 12:56 PM
Momentum's Avatar
220 is a good CR for my setup?
Looking into getting it tuned now... long wait around here though...
Old Jun 23, 2008 | 08:26 PM
civickiller's Avatar
i ran a 14.9 with push button vtec at 95mph. fully stock lsv with smashed open header. dyno tuned at 161hp, first pull made 145hp. so yeah like everyone else says get it tuned
Old Jun 24, 2008 | 01:00 AM
Default Re: (civickiller)
Well here is my time slip...
Now the track I went too wasnt exactly 1/8th mile. It was more like 300 ft or so. IDK, I guess you can still see my 60 ft time and stuff.
Reaction---- .3331
60 ft-------- 2.4309
1/8 ET------ 6.3507
1/8 mph---- 52.08
As you can see my reaction time wasnt the greatest...but like I said this was my first time drag racing EVER!... This was actually my 2nd run out of the 3 I made that night.
I really got to get some drag radials or something...My tires were spinning badddddd...
Old Jun 24, 2008 | 06:42 AM
Momentum's Avatar
Plus, times up here in canada are a lot slower than down in the states i hear
Old Jun 24, 2008 | 07:10 AM
JusAnother1's Avatar
You should be running much faster than that. I had a similar set up with a stock B16 tranny in a crx and was low 13's
Old Jun 24, 2008 | 07:34 AM
Momentum's Avatar
Ive been looking for a tuner, but everyone in the city here i have heard is either being sued, screwed over one of my buddies, blown up a bunch of engines, or doesnt tune hondas...
And they charge $150 an hour!!!
Im in Edmonton, Alberta
Momentum
37
Apr 14, 2011 02:33 PM
DoWork17
21
Aug 24, 2009 04:11 PM
Momentum
May 12, 2008 10:34 PM
Momentum
May 1, 2008 01:01 PM
codyellis
Feb 28, 2008 02:02 AM
