Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2007 Honda Civic EX Wiper Nozzles
Old Jun 19, 2008 | 07:21 AM
darkstar107's Avatar
Default HELP - 2007 Honda Civic EX Wiper Nozzles
I have a 2007 Civic EX. As of recent, everytime I hit a bump wiper fluid sprays out the nozzles. I have taken the car to a local shop and they said they can't figure out whats wrong. They said if you hit the side of the tank with your hand it sprays out as well. No dealership in my area has heard of this happening either.
Dealerships suggested changing the nozzles, but I find it hard to believe that its the nozzles because they both started doing it at the exact same time.
Anyone have any suggestions?
Modified by darkstar107 at 9:49 AM 6/19/2008
Old Jun 19, 2008 | 03:07 PM
yuning83's Avatar
Default Re: HELP - 2007 Honda Civic EX Wiper Nozzles (darkstar107)
From the diagrams, there seems to be a washer motor. Seems like fluid goes through that to the nozzles, maybe the outlet is stuck open or something.
Does the spray work when operating normally?
Old Jun 19, 2008 | 03:22 PM
Default Re: HELP - 2007 Honda Civic EX Wiper Nozzles (yuning83)
Yes, otherwise everything works as it should. Can you provide a link to the diagram if possible?
Old Jun 19, 2008 | 07:55 PM
yuning83's Avatar
http://www.hondaautomotivepart...81%29
I can't see anything else that could possibly shut the fluid while it's not in use.
Old Jun 19, 2008 | 09:18 PM
Thanks for the link. This will definitely help. It does sound like it might be just something loose around the pump area. I just had fog lights installed and it had been doing it ever since. The shop I took it to is the place that installed the fog lights. Needless to say I won't be going there again. If worse comes to worse I will buy a new pump for it.
Thanks for the info and I will post the resolution once I find time to figure it out.
Old Jun 19, 2008 | 09:56 PM
pd0019's Avatar
my wiper nozzles leak after use at higher speeds (75+)
Old Jun 19, 2008 | 10:02 PM
Default Re: HELP - 2007 Honda Civic EX Wiper Nozzles (pd0019)
It squirts out though, its not leaking. And I am only doing maybe 60 Km/h when this happens. It shouldn't be happening
Old Jun 19, 2008 | 10:14 PM
pd0019's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkstar107 &raquo;</TD></TR><TR><TD CLASS="quote">Dealerships suggested changing the nozzles, but I find it hard to believe that its the nozzles because they both started doing it at the exact same time. Anyone have any suggestions?</TD></TR></TABLE>
have the dealership replace them...you should not have to do it. that is why there is a warranty. dont let them say that you have to do it or that you should go and pay for something. if they refuse, file a complaint.
to back yourself up, take a video of this happening.
Old Jun 19, 2008 | 10:23 PM
That will be the last resort. I have to take the undercarriage partially off to change the fog light bulbs, so I will take a look at it then. Otherwise, the closest dealership is 2 hours away so will have to hold off on the dealerships resolution.
Old Jun 20, 2008 | 02:00 PM
yuning83's Avatar
I hope the shop that did your foglight didn't splice bouch of wires and doing it incorrectly to cause this.
Old Jun 20, 2008 | 02:04 PM
When they looked at it the second time they said that they disconnected the wiper pump's power and it still squirted out when the tank was bumped. So it definitely isn't electrical.
Old Jun 22, 2008 | 02:56 AM
yuning83's Avatar
I'd look for anything on that diagram starting from the nozzle back to see if there is something that supposed to shut the fluid off when not in used and it's stuck open for some reason. But then again, if it's open but the pump is not on, where is the pressure that pushed the fluid out? If the bump on the tank could squirt out, too much fluid? If you get to the dealer for the fix, update us on what happened, might come in handy if it ever happens to me.
Old Jun 22, 2008 | 10:30 AM
Ya, I will for sure. I might take a look at it next weekend. But doesn't sound like a very common issue because no dealership in Alberta has heard of it happening.
Old Jun 23, 2008 | 09:00 PM
yuning83's Avatar
I'm not surprised, you are the first I have seen with this issue.
Paceta
Jun 11, 2013 06:51 PM
94eh2
Sep 14, 2012 04:45 AM
aleks708
Honda Civic (2001 - 2005)
May 4, 2010 09:32 PM
eK9aT10pSi
Texas -OK -LA (Sales)
Oct 28, 2005 08:41 AM
