Stock spark plugs on '06 DX to last 80K miles?
Does anyone know what sparks they put in stock '06 Civic? (DX).
Is it those 80K-100K miles platinum ones?
The maintenance guide says to replace them in Sub-Item 4 which is probably 60 or 80K miles since in involves timing belt replacement.
Sub-Item 4
- Replace spark plugs
- Replace timing belt and inspect water pump (V6 only)
which comes after:
Sub-Item 3
- Replace transmission fluid
So, if I got 45K miles on mine, I can wait till about 80?
Sounds awfully long for spark plugs.
Sub-Item 4
which comes after:
Sub-Item 3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viccard »</TD></TR><TR><TD CLASS="quote">Does anyone know what sparks they put in stock '06 Civic? (DX).
Sub-Item 4
which comes after:
Sub-Item 3
Sounds awfully long for spark plugs.</TD></TR></TABLE>
timing belt at 60k-80k huh?
are you sure you're looking at the maintenance guide for the honda civic?
Modified by kroze at 2:41 PM 6/23/2008
Sub-Item 4
which comes after:
Sub-Item 3
timing belt at 60k-80k huh?are you sure you're looking at the maintenance guide for the honda civic?
^ x2. yea are you sure you're looking at the right manual? fg/fa no longer have timing belts, they have timing chains which do not need to be replaced at 80k. they should actually last the lifetime of the car if nothing major happens to the motor.
as for your spark plugs. i'd replace them by 60k max, but i guess you could go up to 80k. with spark plugs there is no definite mileage to replace them, you should just check them regularly after 30k?.
Barmaleyka
Aug 29, 2014 09:11 PM
drmaster
Jan 10, 2007 07:26 PM
ludewithanh22
Oct 9, 2004 11:56 AM
