2000 Honda Civic-resetting the ECM
Old Jun 19, 2008 | 05:06 AM
denb23's Avatar
Default 2000 Honda Civic-resetting the ECM
I was wondering if there is a way you can reset the ECM yourself or do you have to take it to a Honda tech or a dealer to do that?
I'm hoping this will be the fix for my A/C problems. I've had my mechanic and my brother (electrical expert) test the compressor and it works fine. The switch works. He determined that the ECM isn't sending a proper ground signal to the relay. And, an electrical expert at work suggested resetting the ECM as a possible fix. How can I do this?
Old Jun 19, 2008 | 05:09 AM
pdiggitydogg's Avatar
Disconnect the battery for 30 seconds or so and reconnect.
This will not solve the A/C issue, however. But you should at least try it.
Antonio Joseph
Honda City
Dec 19, 2018 06:58 AM
pgk1025
Nov 24, 2017 07:42 AM
jesseironman
Jun 15, 2017 02:23 PM
veej77
Mar 13, 2015 08:14 AM
919leveris
Nov 24, 2012 07:18 PM
