Confused about GSR motor/tranny
Old Jun 19, 2008 | 03:14 AM
VTi_b0i's Avatar
Default Confused about GSR motor/tranny
Hey all, im just a little confused as to where my motor came from as i was told at first it was from japan and is jap spec, but now ive descovered its actually a GSR motor swap.
my engine has B18C stamped on it and underneath has 1004XXX on it and my gbox has Y80 on it and the head says P72. and also VTEC kicks in at 4400rpm...
the thing that has me stumped tho is it states the top speed is 130mph or 209km/h BUT i have a speed cut at 180km/h. i wasnt aware that american cars had speed cuts?
Old Jun 19, 2008 | 04:05 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Confused about GSR motor/tranny (VTi_b0i)
A USDM GSR would be stamped B18C1. Both the JDM SIR and USDM GSR used the same (P72) cylinder head. Your B18C is JDM. A USDM ECU has not speed governer. A JDM ECU does at 180 kmh. You can identify a USDM ECU with the P/N. It would read 37820-P72-A##. The A is the key indicator.
You are in Australia, I thought the GSR was a USDM only vehicle.
Old Jun 19, 2008 | 04:20 AM
VTi_b0i's Avatar
Default Re: Confused about GSR motor/tranny (Dogginator)
yeahh but my motor was imported...does a jap spec b18c SIR motor hit vtec at 4400rpm? cause mine does lol its all so confusing haha
Old Jun 19, 2008 | 04:50 AM
Dogginator's Avatar
Daisy... Daisy...
It should still hit VTEC at 4400 RPM. The cams, head, and intake manifold are the same as the USDM GSR. VTEC is determined by the ECU. Check the p/n.
I think the only substantial difference between the USDM and JDM engines is the pistons, which have a slightly high compression ratio in the JDM engine.
Old Jun 19, 2008 | 06:21 AM
zerovandez's Avatar
I have a JDM GSR motor. My vtec kicks at like 5k and my secondary butterfly at 6k. The ecu i'm using is a p72-a04.
Old Jun 19, 2008 | 06:29 AM
g0tgot's Avatar
dont thread jack fo0
Old Jun 19, 2008 | 10:17 PM
VTi_b0i's Avatar
thanks heaps guys... so the only way to check is by the ECU ay.. where can i find that? haha ive never had to look at it b4
Ricky Ng
May 18, 2019 07:23 PM
Records
Feb 27, 2012 03:19 PM
wolfdawg
Jun 8, 2008 12:52 AM
Int3gra Smokn U
Sep 27, 2004 10:06 PM
hotintegranights
Dec 21, 2002 05:20 PM
