q's for those who know alot about swaps
is there a difference between a chassis with a hydrolic clutch and a chassis with a cable clutch because the rear engine mount on my [<U> 93 dx 4door with hydrolic clutch] </U>is to far over to the drivers side the <U> [ b18a1 cable clutch] </U>came out of a 92 teg i tkink a da chassis where can i find mounts for it? thanx for taking the time to read this
Modified by just getting started at 1:43 PM 6/20/2008
Sounds like your trying to put a cable operated trans into a hydro designed chassis. Sell the cable one and buy a hydro one, all your problems will be solved.
The rear mount bracket for a 90-93 Integra is different than the 94-01 one.
You can either buy a hydro tranny and use the mounts/brackets from a 94-01 Integra
or
You can buy a custom mount kit from the likes of HASport that is made specifically for the engine/tranny you're using in that 93 Civic.
or
95civickid
14
Apr 22, 2005 09:15 PM
HamiltonRex
Dec 23, 2004 04:33 PM
