A rear wheel whining noise. Not a wheelbearing problem. Please help!
Old Jun 18, 2008 | 06:58 PM
vigorhy's Avatar
Default A rear wheel whining noise. Not a wheelbearing problem. Please help!
My car is 2001 accord, rear drum brakes without ABS. It has a rear wheel whining noise for several months when the car turns right, and it is getting worse. Many people suggested it is the problem of the wheel bearing. So I replaced it with a brand new one, but surprisingly, the noise still there, not even better.
What would that be? Someone said there are only two things making noise, brake and bearing. The rear brake works ok, except some rust on drum surface, and this rust dose make rubbing noise when rotating.
Can anyone help with it?
Thank a lot!
Old Jun 18, 2008 | 07:08 PM
TheMuffinMan's Avatar
He knows where you live!
Brake pad dragging or something? Did you disassemble the drum?
Old Jun 18, 2008 | 07:18 PM
vigorhy's Avatar
brake is normal. I didn't feel anything abnormal when applying brake and even hand brake. I didn't disassemble the whole rear brake, but just took out the drum.
Modified by vigorhy at 5:14 PM 6/19/2008
esahic
Suspension & Brakes
Aug 28, 2010 02:18 PM
BringIT
Apr 8, 2010 05:16 PM
FirstTimer00Si
Feb 19, 2007 11:08 PM
user 6297290
Feb 23, 2006 05:34 AM
poppycock
Aug 1, 2004 04:42 PM
