Couple questions before freshening up!?
Old Jun 18, 2008 | 04:40 PM
mister_ej2's Avatar
Default Couple questions before freshening up!?
alright so i have the * * jdm * * 97 spec R motor.....loving the motor from day one.....although ive been through a good bit with the car lol (long story)
on to the good stuff:::::::
i am wanting to "freshen" the motor up, the motor has around 74k on it (bought from jhot with about 67k). i am probably going to redo the head with arp studs definately but unsure with the rest.
one question is, are the later ITR cams better/more aggressive than the 97 and if so is it a big difference.
and if i do decide to get, i guess around 2000-2001 cams, what aftermarket valvesprings, retainers, etc....can i go with if any?
i am wanting to freshen it up with a couple extras but dont want the car down too long, because i do not have the funds for the *good stuff*.....(bigger cams)
i have a hard time explaining things but hopefully somebody will help out.....
thanks
edit::::i guess i should put i have an ARC intake (just the pipe) w/ an apexi filter (both came with the motor) and i have a 98- spec jdm 4-1 header
Modified by mister_ej2 at 7:01 PM 6/18/2008
Old Jun 18, 2008 | 05:59 PM
mister_ej2's Avatar
Default Re: Couple questions before freshening up!? (mister_ej2)
also any sites with the best prices for the aftermarket parts....bump
Old Jun 19, 2008 | 04:39 AM
mister_ej2's Avatar
anyone
Old Jun 19, 2008 | 06:13 AM
CW-ITR's Avatar
74K miles is low mile for an ITR engine. Are you looking to mod it up al ittle bit or is there some thing wrong with the engine?
Old Jun 19, 2008 | 06:31 AM
mister_ej2's Avatar
Default Re: Couple questions before freshening up!? (CW-ITR)
yea especially for a 97....came out of the 4dr (DB8) R.....but as far as modding just putting newer R cams if they help and aftermarket springs, retainer, etc....but nothing is wrong with the motor....just smoking when in VTEC....and i have heard that the R likes to get new valve stem seals and maybe some piston rings while around 80k
Old Jun 19, 2008 | 06:34 AM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mister_ej2 &raquo;</TD></TR><TR><TD CLASS="quote">
The intake cam was diff and the exhaust cam is the same. You can continue to use stock springs/retsiners if you like.
Old Jun 19, 2008 | 06:38 AM
mister_ej2's Avatar
Default Re: Couple questions before freshening up!? (get RIGHT)
how much of a difference would the intake cam make....in hp gain/ feel any stronger?
Old Jun 19, 2008 | 06:46 AM
CW-ITR's Avatar
If I were you, I will just replace valve seals to take care of the smoking in v-tec. The newer CAMs don't realy do much when compare to the '97 CAMs. Advance the timing by 2-3 degree may yield the same result and it is free Heck, take off the power steering belt will free up 4-5 HP to the wheel and that is also free. So, as you can see, there are other worthy mods that you can do beside spend $200-$300 on newer ITR CAMs and only get 4-5 HP to the crank
Old Jun 19, 2008 | 07:30 AM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mister_ej2 &raquo;</TD></TR><TR><TD CLASS="quote">how much of a difference would the intake cam make....in hp gain/ feel any stronger?</TD></TR></TABLE>
FWIW, after riding in both back to back. My "butt dyno" could not tell the difference. Sure, there is a diff but I couldn't "feel" it.
Old Jun 19, 2008 | 08:11 AM
CW-ITR's Avatar
FWIW, after riding in both back to back. My "butt dyno" could not tell the difference. Sure, there is a diff but I couldn't "feel" it. </TD></TR></TABLE>LOL...See what I mean.
Old Jun 19, 2008 | 08:50 AM
mister_ej2's Avatar
so just stick with the cams i have now?.....and i will probably still get aftermarket (supertech, toda, omnipower etc..) springs/retainers etc...just for a little extra fun i guess...hopefully they will be worth the money....
i will also do reg. maintenance (t-belt, water pump, all that good stuff) and also a new oil pump too...
but as far as porting and polishing, and valve jobs what should be done?
oh and thanks for all the advice guys
Old Jun 19, 2008 | 09:01 AM
1999all_motoR_teg's Avatar
What "extra fun" do expect from aftermarket springs and retainers?? All they allow you to do is rev higher which is completley pointless in a stock motor as you don't make power any higher.
Old Jun 19, 2008 | 09:55 AM
mister_ej2's Avatar
Default Re: Couple questions before freshening up!? (1999all_motoR_teg)
for later on, go ahead and get them in there, if i do decide to BUILD the motor....calm down lol
Old Jun 19, 2008 | 10:29 AM
coolhandluke's Avatar
No point in replacing the oil pump. Honda oil pumps literally can last 200,000 miles. PM user Aquafina and he can get you suited with a valve train set. He was an Expo sponsor and is a dealer for Rocket Motorsports, Supertech, etc. You could even ship him the head and have him do the assembly. Make sure and buy OEM honda parts and always get them from Len at Son's Acura. They were also an Expo sponsor but also give honda-tech members 10% off.
1QwIkEf
Jan 7, 2009 07:36 AM
mister_ej2
Jun 19, 2008 11:56 AM
waijsR
Jun 14, 2006 05:45 AM
thehatchninja
Jun 10, 2005 11:37 AM
