Liquid coming from the muffler
i just replaced the head gasket on my b18c1 in my sol and it still smokes white when reved
and now i noticed their is a liquid coming from the muffler and it is very gas smelling
im wondering if its getting to rich
its a OBD1 motor in a OBD2A chassis
with a chipped ECU and a jumper harness
I highly doubt gasoline is pouring out of the tailpipe, unless you hooked up a fuel line to the exhaust
What color is the "liquid"?
Bump after 6 minutes huh
no i just got the head milled and **** and just bought a new head gasket
i think the coolant just need to burn out of the exhaust
and
id like some help on the liquid please
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">you do realize that any liquid that passed through your exhaust system is going to smell like fuel due to the residue thats spans the length of your exhaust system?
x2
if youre running that rich, you'd be getting some serious black smoke. chances are youre just blowing out the rest of that coolant in your exhaust system. I wouldn't worry about another blown head gasket unless youre having performance issues or misfiring/rough idle. if it concerns you enough, do a compression test on it... but from what you described, i think youre fine buddy.
x2
ok i figured out that the liquid is gas
# 4 injector is like stuck open and it sprays the whole time it doesnt pulse
and i havent ran it since the head gasket install
i started to do a comp test only on 4 and 3 cylinder so far and then a **** load of fuel came out the # 4 cylinder spark plug hole
at that time it was a lil above 180 on 3 and 4
xsharpiex
Aug 27, 2009 10:27 AM
