Penzoil synchromesh - hard to get into first gear?
Old Jun 18, 2008 | 08:48 AM
-[95cxhatch]-'s Avatar
Default Pennzoil synchromesh - hard to get into first gear?
Just curious... does anyone else have troubles shifting into first gear with Pennzoil synchromesh fluid? Stopped or rolling...
Old Jun 18, 2008 | 09:02 AM
z6hatchboy's Avatar
Default Re: Pennzoil synchromesh - hard to get into first gear? (-[95cxhatch]-)
seeing as how you just changed it i guess, are you sure theres enough in it, since it doesnt matter if its rolling or not.
Old Jun 18, 2008 | 10:34 AM
instrument's Avatar
your fluid shouldn't be an issue, and i've never found a rolling start into first easy in a sohc though you haven't told us what you're driving.
Old Jun 18, 2008 | 12:50 PM
gsr tranny with ls 5th.
Old Jun 18, 2008 | 12:52 PM
I doubt it is the fluid causing the shifting issue..
Every Honda I have owned has had the famous first gear shifting troubles.
If I let out of the clutch (exedy twin disc) a little bit it usually goes right into gear.
Could be an issue with the linkage or synchro...
Old Jun 18, 2008 | 01:07 PM
bmoua's Avatar
i'm using pennzoil synchromesh on my y8 tranny and no probs here.
deejae
Nov 16, 2013 02:39 PM
azntuner
Feb 2, 2008 08:27 PM
The Phil
Mar 18, 2005 08:27 AM
elevatethis
41
Nov 24, 2003 12:02 AM
geminis2k
Feb 23, 2003 12:53 PM
