Classic Hondas All Pre-1988 Hondas.
1987 honda civic battery drain? please help
Old Jun 18, 2008 | 08:08 AM
sailor23's Avatar
Default 1987 honda civic battery drain? please help
I have a 1987 civc hatchback with 368,000 miles. The car runs great, but recently the battery died; so I replaced it. The second battery died overnight. Then I noticed that the hazard connector on the positive terminal was broke so I replaced it. Jumped off the car and the battery died in about two hours. Obvilosly something is draining it, but I am at a loss for what it could be. no lights are on, and the key is not in the switch. I am thinking of replacing the switch to see if that corrects it. Any suggestions? please?
Old Jun 29, 2008 | 07:22 PM
Crx Jimmy's Avatar
Default Re: 1987 honda civic battery drain? please help (sailor23)
you have to hook up a dmm to the battery and then see how much power is being drawn. then remove every fuse one by one till the draw is gone, this way you know what circuit the problem is with
Old Jul 6, 2008 | 08:40 PM
yayoda420's Avatar
when you hook up a dmm too check for a draw make shere the doors closed but you can also disconect the ground and hook up a test light from the cable too battery if you dont have a dvm it works the same
Old Jul 16, 2008 | 05:58 PM
85ZC's Avatar
Banned
Is it an Si (fuel injected)? My 85 Si had a bad ECU and was draining the battery. I think we put a test light in series with a battery cable and started unplugging stuff until it went out. It was the ECU. Replaced it and all is well now. Sometimes water gets in the floorpans.
Carol Martin
Honda Civic (2006 - 2015)
Mar 28, 2019 06:04 AM
PoisonRitualz
Oct 24, 2018 02:20 PM
niceprelude
Feb 26, 2017 08:03 PM
_Phenom_
Honda Civic (2001 - 2005)
Mar 24, 2010 03:16 PM
LSracing94
Aug 19, 2007 08:07 AM
