jdm itr.. switch vtec solenoid...now oil light comes on
Old Jun 17, 2008 | 05:48 PM
CRX_RR's Avatar
Default jdm itr.. switch vtec solenoid...now oil light comes on
i did a jdm itr swap and had to switch vtec solenoids over because it did not have a oil pressure switch. so i used a 95 and up gsr. when i finish with the swap, started her up and was running for a bit till the light came on. also when i sent in my wires threw rywire they added an additional plug, the oil pressure switch. and the plug only had a one wire to it, idk if it suppose to have 2 wire or one wire. and thats probably why my oil light is on. i check the other oil sensor and its good. any ideas?
Old Jun 17, 2008 | 07:22 PM
Crx Jimmy's Avatar
Default Re: jdm itr.. switch vtec solenoid...now oil light comes on (CRX_RR)
On the 2 pin plug the other wire is a ground
Old Jun 17, 2008 | 09:08 PM
CRX_RR's Avatar
Default Re: jdm itr.. switch vtec solenoid...now oil light comes on (Crx Jimmy)
i don't get it why would they only have 1 wire to the oil pressure switch.
Old Jun 18, 2008 | 08:29 AM
Tubs's Avatar
you need oil
xChrizcrozzx
Jul 30, 2015 08:35 AM
91 DA Revived
Oct 28, 2010 05:25 PM
shepn8tr
Apr 13, 2008 06:44 AM
FlyingDaggers
Nov 9, 2007 11:48 AM
