what screws to use on weld magnum
Old Jun 17, 2008 | 04:37 PM
xtremvw's Avatar
Default what screws to use on weld magnum
got some 13x8 on 26x8 13 slicks would like to screw them in, do i just use 1/4 self taping screws? never screwed them on but would be better to do it..
thanks
Old Jun 17, 2008 | 04:55 PM
1992Si's Avatar
First off, how much HP ?
I have two different sets here, for our car when we get good slicks.
One set is from Jeg's p/n 65040 #14 grade-8 zinc Dichromate screws with proper size drill.
And Moroso p/n 90100 grade 8 steel zinc rim screws.
If your low hp less then 400, I don't think you really need them.
Old Jun 17, 2008 | 04:59 PM
xtremvw's Avatar
Default Re: (1992Si)
thanks for the reply but im making 615whp 510ft/lbs, did some shakedown at low boost and seem fine but are finaly ready to run all out this weekend.
also how many do you use and you put them on both side.
Old Jun 17, 2008 | 05:33 PM
1992Si's Avatar
Yes I believe there's 16 holes,
Innes has a template that spaces the screws nicely.
I used black marker then used a center punch, then used a starter/small drill then the recommended drill. Deburr the holes and get your 1/4 drive bit for the drill and start putting the screws in. You don't need to over tighten them.
It's not fun when you break one in the expensive rims.
Old Jun 17, 2008 | 05:36 PM
xtremvw's Avatar
so i just space them even across, i just ordered some. thanks for part number
Old Jun 17, 2008 | 05:41 PM
1992Si's Avatar
Yes.
For 13" you should be fine with 12 screws.
Yes for 12 screws the holes go every 30 degrees
Old Jun 18, 2008 | 03:55 AM
xtremvw's Avatar
Default Re: (rota92)
thanks for the info here is the car in question.
video of when we first started made 565whp on that pass.
Old Jun 18, 2008 | 06:47 AM
VisualAutoMotoring's Avatar
Default Re: (xtremvw)
We also have rim screws available in packs of 40. It will use hex head screws 3/16" drill
On our car we used 10 on the outside and 10 on the inside.
OEMaccord
Jun 3, 2024 09:06 PM
g2tegsown
29
Jul 17, 2008 10:13 PM
msinsky14
Nov 23, 2006 04:26 PM
JSJ EG6
Apr 2, 2003 12:07 PM
Flux
Apr 1, 2003 07:44 PM
