Starter Issues
Old Jun 17, 2008 | 03:21 PM
CALC!_JUST_du_IT!'s Avatar
Default Starter Issues
I'm having some issues with my starter suddenly. It get's no signal when I turn the key. I can start the car by jumping the positive battery terminal to the spade connection (the one on the top) on the starter.
Any ideas why my ignition isn't sending the signal to the starter? I've checked all my fuses, and I've been tracing all my wire connections. Could this be an ECU issue?
Old Jun 17, 2008 | 03:30 PM
instructor74's Avatar
Default Re: Starter Issues (CALC!_JUST_du_IT!)
check the main relay?
Old Jun 17, 2008 | 04:06 PM
Default Re: Starter Issues (instructor74)
There should be a starter interlock relay by the clutch right? How do I find it, and how do I check that it's working properly?
Old Jun 18, 2008 | 09:41 PM
Well, the problem just got a little weirder... I thought I'd see if the problem was with my chipped obd1 ecu. I plugged in my stock obd2 ecu, and it started up just fine. Any idea why this might be happening? My ecu seems to run the car just fine while in operation. It just won't start it with the key.
Old Jun 19, 2008 | 02:49 AM
tortis's Avatar
do ya have an obd1 to confirm your is bad? that is kinda strange.
Old Jun 19, 2008 | 08:31 AM
Default Re: Starter Issues (tortis)
Not an extra one... If anyone in the Bay Area has an extra socketed obd1 ecu lying around, I would much appreciate your letting me borrow it to help me diagnose what's going on
Cole89ef
May 3, 2009 07:23 PM
Thizzed Out
Apr 3, 2009 03:35 PM
B18C1EKhb
May 2, 2005 03:25 AM
Ski11z
Apr 29, 2004 06:17 AM
