OBX LSD on 500+whp b16 hatch
Old Jun 17, 2008 | 01:23 PM
94hatchvx's Avatar
Default OBX LSD on 500+whp b16 hatch
I will be done with my build soon and only have a few more things to order. A basic run down on the car:eg hatch,84mm b16, built head,garret 60-1 w/70ar 255hp,750's, cable b16 trans with act 6 puk. I will be on around 27-30 psi on race gas with 24.5x8x13 hoosiers. My question is should i wait and save up money for an obx lsd? I would like to see the car go into the 10's and would hate to put it back together having that as a limiting factor. thanks guys
Old Jun 17, 2008 | 04:09 PM
94hatchvx's Avatar
Default Re: OBX LSD on 500+whp b16 hatch (94hatchvx)
bump for info
all you guys out there dippin 10's what were some of your limiting factors or misc. parts it took you to get there.
Old Jun 17, 2008 | 05:03 PM
1992Si's Avatar
Save for the LSD.
and some better axles or bring spare axles with you.
Old Jun 17, 2008 | 06:00 PM
94hatchvx's Avatar
Default Re: (1992Si)
ok cool. I have oem axles right now and another pair of oem's just in case.
The car will be getting tuned on a p28 w/chrome pro. Are there any cars out there with High HP running chrome?
Old Jun 17, 2008 | 06:09 PM
BlownHatch's Avatar
Default Re: (94hatchvx)
seat time is what ur gonna need.unfortunatly money can't buy that.good luck and yes there are a few cars out there making decent power on chrome
o yeah i would save up for the lsd
Old Jun 17, 2008 | 06:20 PM
94hatchvx's Avatar
Default Re: (BlownHatch)
Trust me i know. I will be getting a lot of seat time before cranking it all the way up. Thats good, im hopin for around 400 on pump and 5-550 on 112. I will be buying an obx lsd and then will put the car together.
Old Jun 17, 2008 | 07:21 PM
Boner_Ben's Avatar
I would personally run it open diff until you can save for a quaife/wavetrac lsd. The OBX diff isnt that cheap and if it breaks (mine did) then you will end up buying a quaife /wavetrac anyway and spending more money in the long run. I went 10.40's open diff with my 500+whp B16 and cut the same 60's as I do now with a quaife/spool.
Old Jun 17, 2008 | 07:32 PM
94hatchvx's Avatar
Default Re: (Boner_Ben)
Really, How much is the quaife lsd? I have never herd of a wavetrac lsd i will have to check those out. 10.40's? dam thats pretty fast for open diff. What slicks were you running? Care to elaborate on the set up a little more.
Old Jun 17, 2008 | 07:41 PM
SpoolnG2's Avatar
I believe a quaiffe is around $950
Old Jun 17, 2008 | 07:55 PM
Boner_Ben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">Really, How much is the quaife lsd? I have never herd of a wavetrac lsd i will have to check those out. 10.40's? dam thats pretty fast for open diff. What slicks were you running? Care to elaborate on the set up a little more. </TD></TR></TABLE>
The quaife or wavetrac lsd's are usually around $900 but have lifetime warranties so last diff you will ever have to buy. As for my 10.40 open diff B16, it was a stock sleeve je piston/eagle rod 81.5mm b16, stock gsr head with supertech valvetrain, and t3/t67 h.o. turbo, made 570@ 29 psi and went 10.40@142 on M/T 24.5x9-13 slicks.
Old Jun 17, 2008 | 08:09 PM
94hatchvx's Avatar
Ok good to know, lifetime warrantys are always Damn you were really hauling. How much does your car weigh?
Old Jun 17, 2008 | 08:11 PM
Boner_Ben's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">Ok good to know, lifetime warrantys are always Damn you were really hauling. How much does your car weigh?</TD></TR></TABLE>
I think it was about 2400 with me in it.
Old Jun 17, 2008 | 08:38 PM
ek9t72's Avatar
it must be my good lock the obx in my car is taking it like a champ
Old Jun 18, 2008 | 12:38 PM
94hatchvx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t72 &raquo;</TD></TR><TR><TD CLASS="quote">it must be my good lock the obx in my car is taking it like a champ </TD></TR></TABLE>
Im sure the OBX LSD is a great lsd. ANYTHING has the chance of breaking when you beat on it, sometimes not even that. My experiences with OBX have been good and bad so im neutral on the quality of their products.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">I think it was about 2400 with me in it.</TD></TR></TABLE>
Really? Thats awesome, my hatch last time i weighed it was around 2050 but that was before the turbo setup was added and i will soon have a cage.
hondatuner123
May 16, 2006 08:16 PM
