axle seal leaking
Old Jun 17, 2008 | 12:35 PM
hectic57's Avatar
Default axle seal leaking
i have an axle seal leak after i change my intermediate shaft on my jdm b16 tranny. the previous intermediate shaft connects to the axle as a female, i change the intermediate shaft with the male end connects to the axle instead. Now i have an axle seal leak what might be the problem. Please can any help me?
Old Jun 17, 2008 | 06:42 PM
welfarepc's Avatar
the problem is that your axle seal is worn
or your half shaft isnt in all the way
or you put way too much tranny fluid in
if its the seal, just pull out the half shaft, pry out the seal, tap a new one in with some wood or a socket and reinstall
Old Jun 18, 2008 | 02:49 PM
B18CUL8R's Avatar
Default Re: (welfarepc)
i had a trans that kept leaking after i changed the seal. turned out to be a bad diff
if you take your axle out and put your finger in the hole and move it around does the diff move around a lot? if so you had what i had, carrier bearings failed and broke the diff. another way to tell is if its hard to go into 1st gear
if not its probably just the seal or axle aint in all the way.
97grnrs
Jun 10, 2006 09:29 PM
vha27
Nov 17, 2003 07:27 PM
fu*kfaceC1EH2
Sep 12, 2003 09:13 AM
fu*kfaceC1EH2
Sep 11, 2003 01:22 AM
