obd2 b18c in 95 LS, tach problem
Old Jun 17, 2008 | 10:29 AM
IshbOO's Avatar
Default obd2 b18c in 95 LS, tach problem
I know this is probably a common problem.
I have an obd2 b18c1 from a 00 gsr into my 95 LS shell.
Running p72 obd1 gsr ecu.
Using obd2 gsr engine harness.
My tach will not work, I've heard others with the same problem.
Some people say run a wire from the distributor to my tach wire on driver side.
Others say that this gives inaccurate reading, and makes needles jump.
Anyone know what the problem is or know of a fix? thanks.
Modified by IshbOO at 11:46 AM 6/17/2008
Old Aug 24, 2008 | 08:48 AM
chocolatesk8er10's Avatar
Default Re: obd2 b18c in 95 LS, tach problem (IshbOO)
bump, I have the same problem. Does anyone know the reason?
GorData
Feb 22, 2012 06:08 PM
frstbte14
Apr 14, 2007 07:18 AM
teg racer 877
Feb 6, 2006 10:12 AM
nonvtec
Mar 27, 2005 09:52 AM
BbOi0420
Jan 3, 2005 03:16 AM
