check this turbo
Old Jun 17, 2008 | 05:12 AM
hawkturbo's Avatar
Default check this turbo HELP
this i a garrett gt32 turbo Compressor AR .48, Turbine AR .69 My ? is this turbo can make 400+++++ at 15lbs whit LS/Vtec in top mount setup thanks
Modified by hawkturbo at 6:59 AM 6/17/2008
Old Jun 17, 2008 | 06:34 AM
TheShodan's Avatar
Moderator
Ah, the smaller GT32s, with the 71mm wheel. Those are really good for an LS engine, but the VTEC head utilizes CFM volume so effectively, that it might not be as efficient as actually a larger turbo. 400whp by 15psi will not happen. It will make about 300whp or so at that level of pressure level.
Old Jun 17, 2008 | 08:46 AM
hawkturbo's Avatar
Default Re: (TheShodan)
can upgrade this turbo for hit 380hp at least ok the right ? this turbo i good or not the turbo are high in mi contry and buy another is $$$$$$$ but my hit is 400hp no more than that becuse the gas here is in 85 octane and no good for daili drive got VP fuel and is beter Sorry for My inglish
Modified by hawkturbo at 9:53 AM 6/17/2008
hawkturbo
Nov 1, 2008 06:19 AM
Scotty Dosent Know
Aug 2, 2006 05:04 PM
Keangdawizes
Jun 9, 2005 05:50 PM
SLIMJIMsi97
May 29, 2003 05:31 PM
