4 door ef front spindles the same as an 2 door and auto or manual axles are both the same? 89 hf crx
Old Jun 17, 2008 | 01:17 AM
80 dolla crx hf's Avatar
Default 4 door ef front spindles the same as an 2 door and auto or manual axles are both the same? 89 hf crx
I have a 89 crx hf manual I cant find a trans so i need to ask this
The only ef around me are auto 4 doors.
I am gonna try to use the 4 door spindles on my 89 hf crx so i can use other trannys then the hf. Like the dx, si from crx/ef
Lmk if i can use 4 door spindles just like the 2 door ef and does it matter if its auto or manual?
Old Jun 17, 2008 | 05:59 AM
snowseeker's Avatar
Default Re: 4 door ef front spindles the same as an 2 door and auto or manual axles are both the same? 89 hf
Yes you can use the 4 door spindles. Yes auto and manual spindles are the same. HF's and std's have smaller hubs with I think a 2 less spline count than the si/dx.
Old Jun 17, 2008 | 08:40 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80 dolla crx hf &raquo;</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>you don't need to swap out the knuckles/hubs on your HF to use a DX/Si transmission - just bolt it in and use the HF axles - the only time you need to swap knuckles/hubs is when you are switching to the larger Integra type axles, like for a B-series swap or for a DOHC ZC swap using the ZC transmission and intermediate shaft
Old Jun 17, 2008 | 09:20 AM
Tyson's Avatar
whether you need them or not, you can use them.
just know that EX sedan knuckles have larger rotors, but its more rare to find anyway.
and DX/LX sedans have different rotor size than crx's and hatches. slightly different, i know for sure. not sure if that means the caliper sis completely different or not as well. so just check.
itd be a good idea to swap out the HF front calipers with the knuckles since theyre much smaller.
Old Jun 17, 2008 | 12:58 PM
I know the hf and si dx use the 20-22mm spline.
I Need to know about the manual and auto axles.
This is my problem.
I bought a 89 hf crx it is missing the axles and trans.
The only ef cars i can find around me is 4 doors i know the trans out of a 4 door will work, so i plan on using a dx trans out of a manual 4 door. My problem is i dont have hf axles.
It would be cheaper for me to get the 4 door spindles and throw them on with the 4 door dx trans. (again i know the 4 door ef and 2 door/crx trans will fit)
I need to know if i can use automatic axles and spindles as i can get them for free.
Old Jun 17, 2008 | 01:51 PM
Tyson's Avatar
automatic "spindled" aka knuckles, will be fine.
im not 100% sure on the axles, im pretty sure its ok.
Old Jun 17, 2008 | 02:06 PM
SIred91's Avatar
Rainman
Auto and manual axles are the same, just the differences between models like already discussed.
100% positive.
Old Jun 17, 2008 | 07:15 PM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80 dolla crx hf &raquo;</TD></TR><TR><TD CLASS="quote">I know the hf and si dx use the 20-22mm spline.
This is my problem.
I need to know if i can use automatic axles and spindles as i can get them for free.</TD></TR></TABLE>
What parts do you need? I may be able to help you out. PM me!
Old Jun 17, 2008 | 10:05 PM
I cant pm i am still a newb status
I need local so that way i can save on shipping and prevent me from getting ripped off, while making sure the said items are in working order.
Old Jun 19, 2008 | 09:04 AM
Would ex axles off a 99 (or any year 90-00)and shift linkage work on my hf crx 89 as long as i use dx/si hubs off another ef?
Old Jun 19, 2008 | 12:16 PM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80 dolla crx hf &raquo;</TD></TR><TR><TD CLASS="quote">Would ex axles off a 99 (or any year 90-00)and shift linkage work on my hf crx 89 as long as i use dx/si hubs off another ef?</TD></TR></TABLE>
I haven't tryed but I highly doubt it.
gunnerman
17
Jul 9, 2009 04:25 AM
luck1e
Aug 11, 2004 12:29 PM
Timmah!!
Jul 9, 2003 04:02 PM
whitemike1644
Jun 23, 2003 09:42 PM
lawabidn
17
Nov 13, 2002 09:04 AM
