HELP new kyb ajust able with stock springs noise
Old Jun 16, 2008 | 11:23 PM
mario_pic's Avatar
Default HELP new kyb ajust able with stock springs noise
oke i just did my rear struts and what i did was i used my stock springs with kyb ajust ables i noticed every time i go off a bump it makes a clang nouise like the springs moveing or somthing what can i do to stop it
Old Jun 17, 2008 | 06:57 AM
mario_pic's Avatar
Default Re: HELP new kyb ajust able with stock springs noise (mario_pic)
bump
Old Jun 17, 2008 | 06:59 PM
welfarepc's Avatar
did u leave the dust boots on? if so i HAD to remove them.
i bet thats it.
Old Jun 17, 2008 | 07:13 PM
gringo7718's Avatar
Default Re: (welfarepc)
#15 must be removed in order to use KYB AGX rear shocks.
Old Jun 17, 2008 | 08:07 PM
Ch3vy3ater's Avatar
does it clunk when you turn the wheel? If so bearing paltes needs aligned.
Old Jun 17, 2008 | 09:17 PM
mario_pic's Avatar
Default Re: HELP new kyb ajust able with stock springs noise (Ch3vy3ater)
only on speed bumps and yess i used the duct cap also it stoped today should i be woryed oke also if i take the dust caps and put them in a pipe streacher will it work after words or will thay still be a problem and if i cant use the dust caps what should i use insted
Old Jun 17, 2008 | 09:18 PM
mario_pic's Avatar
Default Re: (gringo7718)
also # 18 is not there it crumbled
Old Jun 18, 2008 | 08:30 AM
Tubs's Avatar
normal
Old Jun 18, 2008 | 09:51 AM
sgallagher's Avatar
If #18 is the spring pad. I can really tell from the diagram. Then you have the spring and strut contact metal to metal every time the spring wants to shift it will cause noise.
Remove the struts remove the dust boot and install the spring pads and your noise should go away.
ex_ricer
Jan 21, 2008 07:36 PM
ex_ricer
Suspension & Brakes
Jan 21, 2008 07:31 PM
rivoe302er
Apr 3, 2007 09:09 PM
ERIC!
Jul 4, 2005 01:47 PM
FG Two
Nov 26, 2002 10:41 PM
