jdm b16 motor mount?
Old Jul 17, 2002 | 03:28 PM
90_Civic_Hatch's Avatar
Default jdm b16 motor mount?
while trying to install my 2nd gen jdm b16 into my 93dx hatch, I ran into a problem my driver side mount. When I tried to put the one from my dx motor on the b16 it was crooked. What kind of car can I get the mount from? 94 and up Integra? or a delsol b16. Also which 2 of the vtec wires are which?
Thanks
Old Jul 17, 2002 | 06:24 PM
Default Re: jdm b16 motor mount? (90_Civic_Hatch)
ttt
Old Jul 17, 2002 | 06:42 PM
VTECVillain's Avatar
The mount from a 94-01 Integra will work.
Old Jul 17, 2002 | 06:47 PM
Plan B's Avatar
Default Re: jdm b16 motor mount? (VTECVillain)
the civic ex mount will work also, it would probably be cheaper to get at a salvage yard
Old Jul 26, 2002 | 01:04 PM
nsxmatt's Avatar
Default Re: jdm b16 motor mount? (Plan B)
The integra mount doesn't work. I just got mine in and the b16 mount has two offset bolts while the integra mount has two straight bolts.
Are you sure the sohc vtec mount will bolt on to the jdm b16 mount? If so that would save me a big headache!!!!
Old Jul 28, 2002 | 01:09 PM
93dx--hatch's Avatar
Default Re: jdm b16 motor mount? (nsxmatt)
do I have to use the front mounts that were on my dx motor. The mounts that are on the block next to the header. I am doing a second genb16 in a 93dx--hatch. Or can I just leave those mounts off? I think i have seen cars without them.
Old Jul 28, 2002 | 01:37 PM
Plan B's Avatar
i answered that wrong, get the bracket from an integra that bolts directly to the block, it's like $60 it will work with your civic.
Old Jul 28, 2002 | 02:21 PM
nsxmatt's Avatar
So what your saying is you can't use the ex/si mount on the top timing belt side mount? I looked at the mount that connects to the block, the part that has the two bolts sticking up. My stock sohc vtec mount looks to have the same bolt pattern (two offset bolts the same offset) and looks like it should work.
Old Jul 28, 2002 | 08:11 PM
it depends on your motor some of the second gen b16s had offset mounts and some were strait. But does anyone know if i need to keep the two front mounts or can i get rid of them I am reffering to the mounts that are parralel with the header one on the tranny one on the block. And no i don't have poly mounts
Old Jul 28, 2002 | 08:53 PM
nsxmatt's Avatar
Default Re: jdm b16 motor mount? (93dx--hatch)
The front two motor mounts do provide some help from the motor tilting back and forth i'm sure. I've seen them without the a/c bracket also but i'm sure it's better to have them on. But if your in a pinch...
Old Jul 29, 2002 | 08:57 AM
would the brackets from a 94integra work on a 93dx hatch? On a second gen b16
Old Jul 29, 2002 | 09:14 AM
dogpile5's Avatar
25 Year Member
the driver side upper mount is actually two pieces. separate it and replace the "L" bracket that bolts directly to the block with the bracket from a 94+ integra. the upper piece (round, usually brushed aluminum) will bolt into this and feed through the motor mount in the frame of the car.
i picked mine up through http://www.sohfast.com for 40 bucks
[Modified by dogpile5, 1:14 PM 7/29/2002]
Old Jul 29, 2002 | 06:34 PM
Plan B's Avatar
Default Re: jdm b16 motor mount? (dogpile5)
the one from your single cam will not bolt to the dohc block.
edit: i meant the bracket, re-use the round mount that actually bolts to the car.
[Modified by Plan B, 10:35 PM 7/29/2002]
Old Jul 29, 2002 | 07:32 PM
nsxmatt's Avatar
Gotcha. I kept getting conflicting answers on the sir 2 b16 mount. Some came with a integra type mount that uses the integra top round mount and some with the offset mount which uses the 92-95 top round mount. Pretty confusing since alot of people don't know. Now I have a integra upper mount to get rid of BTW do you have a pic of your drivers side mount or one like were talking about? Thanks
blackrocky
Aug 7, 2008 08:39 AM
BOMBCRU
May 23, 2005 11:33 PM
SkunkCrxSi
18
Jul 23, 2004 07:34 AM
b16_madman
Dec 19, 2002 01:59 PM
