should i get open or close ended lugnuts??
Old Jun 16, 2008 | 08:00 PM
ShinotakuX's Avatar
Default should i get open or close ended lugnuts??
i like the look of the extended open ended lugnuts on wheels, they look really nice, but does it damage the studs? like corrosion or rust? anyone have problems with this? thankx
Old Jun 16, 2008 | 08:11 PM
ke98248's Avatar
Default Re: should i get open or close ended lugnuts?? (ShinotakuX)
I'd go with closed lugnuts if I were you.. I think you'd be ok as long as you don't drive thru the ocean or drive into huge puddles all day..
Old Jun 16, 2008 | 08:45 PM
bbun's Avatar
if you have extended wheel studs , then open end
Old Jun 17, 2008 | 12:24 AM
moz92's Avatar
extended wheel studs unless you track your car and they require them.
ej8ster96
Aug 18, 2011 02:30 AM
dc5RickK20
Jan 11, 2011 09:38 AM
92bseries
13
Jun 10, 2010 11:18 AM
ricehead
Nov 18, 2009 05:41 PM
gakkuken
21
Jan 10, 2005 02:28 PM
