ok this is a good one..honda del sol radiator problem?
Old Jun 16, 2008 | 07:41 PM
sorullo's Avatar
Default ok this is a good one..honda del sol radiator problem?
[I]my radiator cap was broken .. now. all the pressured coolan was goin into the coolan tank..now i bought a new cap for the radiator.. and guees what.. it just start blowing my coolan hoses...now.. when i had the old cap never happen .. and now that i have the new cap keeps the coolan on the engine under some pressure ,, now it's this normal.. that the radiator is under some pressure?... and guest what the hose that blow up. is the little one that goes from behind the engine and go into the manifold. i guess it goes into a sensor o something..now. i got to take the whole manifold out to be able to put the new litlle hose in.. so what is it??.. the radiator, the ecu, the water pump. or cause i just did the right thing putting a new cap on it and the hose is just starting to give up!! or what!!..
Modified by sorullo at 8:57 PM 6/16/2008
Old Jun 17, 2008 | 09:44 AM
vtecb18c's Avatar
Default Re: ok this is a good one..honda del sol radiator problem? (sorullo)
bleed the system to get the air out
SnoopyMan
Mar 7, 2013 08:26 PM
ls19integra95
Jan 30, 2008 09:21 PM
dmxsoulja3
Dec 16, 2004 03:07 PM
VinceVTEC
Apr 25, 2004 03:19 PM
MaxSterling
Jun 30, 2003 09:51 PM
