intake touched battery.now won't start
all good from under the hood and under the dash. went to go clean my fitv, all of a sudden sparks from my intake and battery. after cleaning went to go install and it dosn't start. nothing, all my lights turn on and everthing but IDK
sounds like a main relay. does th fuel pump prime before i try to turn it over? if not i would bet my money on the main relay. they are designed to keep everything else from shorting out in the event of a short. its a pain in the *** but it saves u in the long run
You either burned out one of the main fuses or killed the power or ground wire from the battery.
The main fuses look like the yellow one in this pic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobjohnson »</TD></TR><TR><TD CLASS="quote">Put electrical tape or a rubber sleeve over your intake.</TD></TR></TABLE>
haha mine is zip tied to my strut bar.
orly?
orly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p10hlm »</TD></TR><TR><TD CLASS="quote">sounds like a main relay. does th fuel pump prime before i try to turn it over? if not i would bet my money on the main relay. they are designed to keep everything else from shorting out in the event of a short. its a pain in the *** but it saves u in the long run
Doesn't sound like a main relay.
it is the big yellow fuse.
my buddy had the same issue.
he said hell it doesn't look blown. you could barely see a crack in the copper electrode. we replaced it with a spare one I had and the car fired right up.
Lmao...
How about buying a brand name intake guys? Did anyone ever think of that?
Lmao...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout8488 »</TD></TR><TR><TD CLASS="quote">
Lmao...
because it's the same ****. The AEM ones come with little rubber pieces to avoid this such problem. Take the precautions and you'll be fine.
Lmao...
</TD></TR></TABLE>because it's the same ****. The AEM ones come with little rubber pieces to avoid this such problem. Take the precautions and you'll be fine.
NotAJDMFanBoy
Apr 21, 2020 08:21 PM
TeamRiskEG6
29
Aug 7, 2008 05:53 AM
lshatch1.8
13
Aug 29, 2006 05:25 PM
