fule injectors
what the best think to to buy new fule injectors or clean them my car runs fine just doing some thing to get it all tune up and if buying new one is the way to go the do i go with stock or bigger one what size do i get. the motor is a 1 gen B16A running OBD 0 full catback, cold air intake, and some other little thing if that will make a def
brand new fuel injectors are pretty damn expensive. maybe its just my cheap *** but if there working why waste the money? i would just take them out and clean them. you definatly dont need biger ones either unless your gona slap a turbo on there.
Please clean up your grammer. On the other hand if it aint broke dont fix it. Unless your not getting enough fuel I wouldnt bother replacing them, if you want go to walmart or autozone and buy some fuel system cleaner that you mix with your gas. Some of this stuff works just watch out for stuff containing alcohol. This will cause your Fuel lines to dry out and corrode. Also you can check resistance and do a voltage drop on your injectors to see how there running.
Mr.Highlife
Nov 15, 2009 04:29 PM
