cluster lights dont work, i searched and done my home work
well my 91 hatch cluster doesnt lights don't work, checked fuses and not it, so i moved to the switch, i have power at all three wires when i turn the lights on, then unplug the switch and only one wire has 12v. my ? where do i go from here? what else can i check? and yes it is a most to have these lights work. thanks
If it's just the cluster lights, take off your cluster cover, remove the cluster and replace the bulbs in back, they just twist out, then you replace them
damn i am having the same problem you are right now...when i finished my rebuild a while back i was driving and then all of a sudden the lights quit working and i have checked everything like u
well did more searching and found the answer, i had to check to see if i had power to the cluster, on plug a, there are two wires i had to check a red one and a red w/blk, those control the power to the lights(90-91) i found out i had power to the red w/ blk but not the other. so i traced the wires to a little black box to the right of the fuse box, and found out i had no power there, so i traced the wire and found a crack in the red wire and fixed it and now im all good, hope this helps some one some day.
lluks_844
Jun 1, 2007 05:01 PM
